Tamiya TA07 pro
#631
Toby- just use Rods set up. So what that's a different car. Tamiya cars all handle very similar. When I went to Japan. My car was really good right from the beginning. I used Tamiya whites up front and yellows in the rear. Medium sway bar up front and light sway bar in rear. 40wt all around. Use the same set of tires for all the entire race. Find some old B2's without sauce and dial your car in
#634
What I see about the TA07 after running it is that everyone that talks about weight and it being heavy is over doing it. After my run this weekend I smoked guys with 419X's and other carbon chassis vehicles, the TA07 is very easy to drive. What i would say to someone that is going to buy this car is to just run it then add options.
Yes you will have to lighten the car but don't over think it, add the current options and learn the car and how to set it up for your driving skill.
The big plus for this car is the ease of driving very smooth and just fun and I love the single belt, check out TOP's new car looks like the same drive train with the single belt.
Add the 419 carbon arms and 4 deg C hubs and spool.
What I would like to see is the chassis stiffener like from Active Hobby to sweet go mine on order. As for TCS it's perfect replacement for the TA05 what a great car.
Guys just drive it then find out what your needs are for this car, Thanks Tamiya!
#635
#636
Yes it does have flex, but I don't see that as a bad thing on anything but the highest of grip situations.
#637
#638
Would you please kindly tell me your best set up so I can smoke Wendra with his 419X.
#639
too Fast Ray... too Fast....
#641
But it is 80% driver, and 20% car I believe..
#642
The car forgives for sure, I also felt very comfortable driving it, and was able to finish ahead of many top-end chassis. Actually, I was slower than a friend who has 419x, but with TA07, we were exactly on the same pace last week. TA07 definitely worked for me so far.
#643
Are any of you guys running USGT with this chassis with the Gravity Ride tires?
#644
Those of you who have switched to TRF418/9 suspension parts: have you noticed an improvement in lap times or is it a psychological thing? I've got the parts, just not sure whether to put them on my 07 or whether they'd be better spent upgrading my TB04 Pro to Pro 2/R spec.
