Like Tree488Likes
Tamiya TA07 pro
Old 12-15-2018, 09:17 AM
  #2116
Hi Tom,so now in your opinion which one from tamiya is more competitive?07ms or 419xr?One thing is for sure that they are all good looking beauties including evo7,especially built up with quality by you. Keep us updated with your test drive,thank you!
riddic is offline
Old 12-15-2018, 01:59 PM
  #2117
Originally Posted by Tom1977
Mine is running smooth. I used the 0.1mm shim at the main pulley but I did not use the 0.1/0.2mm shim at the counter pulley as stated in the manual, because the counter pulley did not run smoothly with shim. I think you have the same issue. It's your counter pulley, not main pulley.
Hint: You have to check the direction of putting the counter pulley onto the axle. The flanged bearing has to be outside to the center bridge!
I wil check this,thank you for this!I think indeed that this is indeed the proble,I will post more later if it is solved,thank you again
freaky321 is offline
Old 12-15-2018, 02:33 PM
  #2118
Jep how could I missed that!,
I did not read the manualvery well...I have indeed installed the pulley in the wrong direction,the flanged side was on the inside,also I have did the same as you and removed the shim at the pulley,.
Thank you very much Tom! You have been a big help!
It is a great car to build,its indeed An 1 belt TRF.
Old 12-15-2018, 08:36 PM
  #2119
rc_square24's Avatar
I noticed on the MS they have changed the colour of the upper arm mounts and the damper spring perches from black to blue. I know some prefer an all blue car but the black and blue contrast was also nice IMO.
rc_square24 is offline
Old 12-16-2018, 02:44 AM
  #2120
I have looked for damper caps for these ultra short shocks in blue,does anyone know a part number for it?
I don't like the blue/black gold combination.
I looked everywhere for Caps that wil fit perfectly but.
Old 12-16-2018, 04:01 AM
  #2121
Tom1977's Avatar
Sadly not available!
Tom1977 is offline
Old 12-16-2018, 09:01 AM
  #2122
My build in progress,lol
Ah damm,too bad,why cant they design a better looking damper.
The car itself looks great but those dampers...
Thanxs anyway
Nicadrauspro4 likes this.
Old 12-16-2018, 09:57 PM
  #2123
MidwestRacer's Avatar
That TA07MS is a sweet looking unit. What surface do you plan to run on. I race pretty much exclusively carpet and mostly black CRC. Thinking of getting one of these to try, but wondering how well it will work on a high traction track.
MidwestRacer is offline
Old 12-17-2018, 09:02 PM
  #2124
minidriver's Avatar
Default Gearing
Can a TA-07 be geared to a final drive ratio of 3.00? Thinking of running this in a locked can 21.5 class, but need to get to a 3.0 to be up to speed at the local track.
I have a nice TB-04, but can't gear it below 3.33 which will not be competitive in the class.
Thanks.
minidriver is offline
Old 12-18-2018, 05:33 AM
  #2125
JoeyE's Avatar
Trader Rating: 45 (100%+)
Thanks.
64P 84T spur 57-58 Pinion
JoeyE is offline
Old 12-18-2018, 01:17 PM
  #2126
nubs's Avatar
Thanxs anyway
Curious, what is your issue with the dampers? I find them to be great looking. Blue bling with some black.
nubs is offline
Old 12-19-2018, 01:10 AM
  #2127
I am just nitpicking lol,I like the design of the damper, but not the colour scheme.
Anyway i have found some blue tamiya caps,that fits like a clove.
I found them within my rc mess,haha
I am gonna use it on an Tarmac track, at my local rc club.
Grip condition at our track really depends on the Weather.
Old 12-19-2018, 01:22 AM
  #2128
double post
Old 12-19-2018, 04:10 AM
  #2129
fat500's Avatar
Trader Rating: 51 (100%+)
How does the MS compare to the ta07 with the psm or exotek chassis?
fat500 is offline
Old 12-19-2018, 11:03 AM
  #2130
Tom1977's Avatar
Race-Ready
1258g
Nicadrauspro4, Qatmix, PDR and 4 others like this.
Tom1977 is offline
