NEW XRAY T2
Old 01-18-2006, 12:04 PM
  #1936
kewdawg's Avatar
Originally Posted by Mike Mandio
Metric screws use a 90 degree countersink. I got mine from McMaster Carr - www.mcmaster.com
Yo' Mike! What's up? Didn't know you hung out here. Then again, I just noticed your 15 posts since 2002! Are you diong the O.R.L., this Saturday, at Pottbellies?
kewdawg is offline
Old 01-18-2006, 12:46 PM
  #1937
Originally Posted by VenomWorldOrder
that's if you can get your hands on a fk05 strap. i think they are on back order with the motor guards
I'm now ready to sell my fk05's if anyone was intersted. I also have one battery brace that I would sell seperately. If you want it , just PM me.
Juan Aveytia is offline
Old 01-18-2006, 12:54 PM
  #1938
You have PM.
Mutabarucka is offline
Old 01-18-2006, 02:03 PM
  #1939
Anthony.L's Avatar
Trader Rating: 41 (100%+)
I just recieved a xray multi-diff to install in my T2. The package didn't come with any one-way lube for the bearings and the instructions don't mention anything about lube. Are they ready to go from the factory or do I need to lube them before running it?
Anthony.L is offline
Old 01-18-2006, 02:07 PM
  #1940
IF anyone needs a FK05 battery strap you can contact RC/Plus (link in signature) Thay have a couple on the shelf.
ChadK is offline
Old 01-18-2006, 02:09 PM
  #1941
you can use that hudy grease they send you for your diffs as a one way lube as it is very thin and wont slow down the bearings that much
goop is offline
Old 01-18-2006, 03:06 PM
  #1942
Joep's Avatar
The one-way is lubed allready and doesn't need initial lubing.
But if you need to re-lube later on you should us 309580 One-Way Lube 25ML
Gr.
Joep is offline
Old 01-18-2006, 03:08 PM
  #1943
Anthony.L's Avatar
Gr.
Thanks! I'll get a bottle of one-way lube on order and run the diff as is for now.
Old 01-18-2006, 04:09 PM
  #1944
Mike Mandio's Avatar
You'd be suprised where I hang out!! Unfortunately, I won't be able to do any Saturday racing until tax season is over. I've got a new T2 just sitting on my workbench waiting to be run. The next time I'll get to run on-road is the February 19th ORL2 at Kranzel's. If you want to try some oval some Sunday at Horsham, let me know. I've got an extra CustomWorks Agressor you can try.
Mike Mandio is offline
Old 01-18-2006, 04:28 PM
  #1945
RobertV's Avatar
My rig ready for the rug:
http://www.deepwest.com/RC/T2/t2-1.jpg
http://www.deepwest.com/RC/T2/t2-4.jpg
I have the 6mm Tamiya hexes on order, Jaco wheels are digging into the knuckles hard. I also chose to grind down the button head screws to mount the PRS gear but other then that the car went together like a dream. I really like the improved front bumper system and of course how easy it is to get to the diffs and the spur.
RobertV is offline
Old 01-18-2006, 04:32 PM
  #1946
HarshGuy's Avatar
NICE ...got the final parts for mine today (speedo, wires and 6 mm hexes) ...so she'll be all put together tonight ..I'll snap some pics of her all done up.
HarshGuy is offline
Old 01-18-2006, 04:48 PM
  #1947
kewdawg's Avatar
Well, don't fell too bad. By the time you can race touring cars on Saturdays, again, there should be plenty of parts avail. for your T2. About the oval car, I appreciate the offer but, isn't the oval racing class at Horsham really small? I recall someone, recently, saying that Horsham will probably do away it because of poor participation. Something about them losing money racing the class on Sundays.
kewdawg is offline
Old 01-18-2006, 04:57 PM
  #1948
DaveW's Avatar
OK. Electronics space is really limited in this car, has anyone considered moving the servo forward a bit in the chassis? There seems to be a bit of room to play with there. I know it will shift the weight of the car some... but it cant be THAT much to move it forward 1/4"... i dont see it being detrimental to handling.
- DaveW
DaveW is offline
Old 01-18-2006, 06:01 PM
  #1949
gonzo416's Avatar
Trader Rating: 39 (98%+)
are you guys using the adjustable pistons in the shocks or the #2 (for carpet stock)
gonzo416 is offline
Old 01-18-2006, 08:59 PM
  #1950
Ill Factor's Avatar
- DaveW
If u relocate the antenna mount to the top deck or just forward of the servo it can create just enough room depending on the electronics. Check mine out.
Can anyone give me an Idea of what gear ratios I should start with for 116 64 p spur, rubber on asphalt.
Ill Factor is offline
