Team Associated TC7 & TC7.1 Touring Car
#2701
Center link chassis stiffener
I was wondering if anyone would help and provide the correct part numbers used if I wanted to run a stiffener from the servo mount to the motor mount.
#2702
it's not really a part number thing, its a drill a hole through the entire motor mount and the chassis ideally (center mount rather than 2), tap it, then cut it halfway down and install ball studs on both sides with a link between them. It's been tested a bunch, not used to win any large races that I know of.
#2703
Suspended
RC Engineers are completely incompetent. .....
#2704
Sure, as everybody knows that there is no difference between lateral flex and longitudinal flex...
#2707
Trying to rebuild a used tc7.1 I bought. I'm having an issue with inserting the pin for the hex into the dcv. I don't get enough of the dcv to stick out to insert it. This is the first time building a TC and I'm 100% sure it fit before I took everything apart. I must be mixing parts up or something... Also a pic of compression - https://ibb.co/kUAO1T
Here are more images :
https://ibb.co/fN4ST8
https://ibb.co/hsGVgT
https://ibb.co/ftWVgT
https://ibb.co/ffPST8
https://ibb.co/hRbVgT
https://ibb.co/hCiAgT
#2708
#2710
Thanks guys, I knew it had to be something easy!
#2711
Help with steering setup
Looking for some advice. I assembled a new 7.1 about a month ago. I built the steering drag link to spec and set the servo arm to vertical, as there was no mention in the manual as to what angle the servo arm should be. It took about 30 steps of left subtrim to get the arm to vertical due to the splines on the servo output. When I setup the steering travel, it takes about 10% more right travel then left travel to achieve the same steering angle on the tires (checking the outside wheel on each side because I know Ackerman will effect the inside wheel).
Back when I flew airplanes and helis, it was always stressed that you should have your link as close to perpendicular to the servo arm as possible to remove differential throw. When I look at the arm now, the angle is probably 30 degrees off perpendicular.
So, I have a couple of questions. First, is this something I should be worried about? I have the same amount of steering angle in both directions, but the servo has to travel further to the right then to the left to achieve that angle. Second, if it a problem, how should I correct it? My first thought is to try and get the servo arm perpendicular to the drag link, but I am afraid that I won't be able to get the drag link short enough if I do that.
Am I crazy for worrying about this? Did I build something incorrectly? Thanks in advance!
#2712
#2715
