Like Tree256Likes
Tamiya TRF419
Old 03-17-2019 | 01:41 AM
  #4276
disaster999's Avatar
Regional Moderator
Originally Posted by Macio4ever
You can buy Vigor battery mounts for 419X.
https://www.tonisport.de/marken/vigo...battery-holder
you still need to use tape for this...the TA07MS battery mounting system might work for this car as it is tapeless, but I havent see anyone try that yet, nor do I know if that mount can be bought separately.
Another way is just by some aluminum standoffs, and some scrape carbon fiber pieces and DIY your own.
disaster999 is offline
Old 03-17-2019 | 02:01 AM
  #4277
Originally Posted by doubleA
is it reliable and safe to buy from this website?
They go under the name 'atyhobby' on ebay. Can often be cheaper to buy through ebay, especially when ebay has coupons/deals, just check what shipping method you use because the cheap shipping option on ebay can take a long time (read: up to a month) to arrive depending where you are located. I've bought plenty of stuff from them both via ebay and their own website and no problems
nbTMM is offline
Old 03-17-2019 | 10:01 AM
  #4278
Raman's Avatar
the TA07 MS are available separately. You need to buy each piece!
Raman is offline
Old 03-17-2019 | 10:17 PM
  #4279
rc_square24's Avatar
Correct theyre available separately, but needs to be special order as they are 7digit spare parts that are not sold in majority of stores.
rc_square24 is offline
Old 03-17-2019 | 11:32 PM
  #4280
Regional Moderator
thats not gonna be cheap
Old 03-19-2019 | 11:45 AM
  #4281
Raman's Avatar
yep they’re around $24 each
Raman is offline
Old 03-21-2019 | 12:06 AM
  #4282
The TA07MS battery holders are heavy. The lower part that holds the battery is made of steel 12.7g (each)
the upper poss and csrbon stand off are light (4g) I think those are made to hold light life batteries and offset the weight.
Qatmix is offline
Old 03-27-2019 | 06:30 AM
  #4283
Any advice for how much oil to fill (in terms of weight in grams) when using the aluminum case and cover for the gear diffs? Since they hold more than the plastic ones.
Thanks!
Old 03-27-2019 | 08:30 AM
  #4284
Regional Moderator
Thanks!
I just usually fill till it covers the cross...i rarely weigh my oil
rc_square24 likes this.
Old 03-27-2019 | 10:24 AM
  #4285
JoeyE's Avatar
Thanks!
Weigh/prop your 1/2 gear diff assembly on a scale and add 1.5g
JoeyE is offline
Old 03-30-2019 | 09:27 PM
  #4286
sonic31's Avatar
17.5 class spur and pinion what's a good starting point?
sonic31 is offline
Old 04-01-2019 | 06:12 AM
  #4287
Thanks!
To reply my own question, I filled the bottom end of the diff to 16g (weight includes lower aluminum case assembly + metal shafts + aluminum joints, I forgot to weigh it dry).
All gears were lightly sanded to remove flashings from the ejector pins/molding on the flat side. Since the green gasket that comes with the aluminum diff cover is slightly thinner than the brown ones from the plastic version (0.4 vs 0.5), using 0.3mm shims on the top and bottom felt way too tight and notchy.
I ended up with 0.2mm (0.1+0.1mm) large bevel shim on the cover side, 0.3mm on the bottom end, and 0.1mm on small bevels (all shims from large diameter shim kit 42313 with orange TRF orings).
So far no leaks yet and feels smooth. Obviously, the above may vary from one assembly to another.
Old 04-01-2019 | 12:59 PM
  #4288
Track size? Motor?
I think if you have a 96 and a 104 on hand you should be pretty covered for most motors. Pinions will vary but you should be able to make most things work out from there.
Troy Carter is offline
Old 04-01-2019 | 04:15 PM
  #4289
sonic31's Avatar
Originally Posted by Troy Carter
Track size? Motor?
medium size track, im sorry i should've paid more attention, im running 21.5 not 17.5 ... i have a 96 i dont have a 104, i put a 100t in there now with a 51t pinion.
sonic31 is offline
Old 04-02-2019 | 06:42 AM
  #4290
The 100t should be good. I don't know where all the current crop of 21.5 motors are being geared but you should be able to get there with that using pinions from 44-51t.
