Like Tree122Likes
Tamiya TRF419
Old 10-09-2018, 12:38 PM
  #4126
nubs's Avatar
I know that a lot of people are saying use one size shim versus another. At the end of the day, the correct shim to use is the one that provide the least amount of slop while not creating too much friction. In otherwords, you need to pay attention when you are sliding the pin into the rear of the outdrive. Do you notice any space between the shim and the pin? If so, increase the shim size. With the new shim, does the outdrive and the diff housing spin independently? If so you are good. If not you need to reduce the shim shize and use a larger o ring. Its all about the balance between slop and free action.
airbiscuit likes this.
nubs is offline
Old 10-09-2018, 01:17 PM
  #4127
Tom1977's Avatar
Tamiya should bring out a blue X-ring for the diffs. Like the blue TRF X-rings for dampers. The sealing area with those rings is bigger than with conventional o-rings and you can squeeze them with a shim without increasing friction.
And X-rings are definitely better for rotating parts, like in real cars.
Tom1977 is online now
Old 10-10-2018, 06:25 AM
  #4128
Setup question :
My car seems to push during corner entry then it will turn into the corner.
Advice on how to remedy this?
airbiscuit is offline
Old 10-10-2018, 06:01 PM
  #4129
Raman's Avatar
Trader Rating: 60 (100%+)
Originally Posted by airbiscuit View Post
Setup question :
hard to say without knowing your set up.
any of the following could help..
1. Increase droop in front
2. Stand up shocks in front
3. Increase steering dual rate.. 2 points at a time
4. Increase front camber 0.5į
5. Lower front roll centre by using shorter camber link spacer
Raman is offline
Old 10-10-2018, 10:40 PM
  #4130
Just what I need. Things that can be done quickly while out on the track.
Thanks!
Old 10-11-2018, 07:14 PM
  #4131
Raman's Avatar
the new BD9 now has roll bars with bearing support.. so Tamiya wasnít the last one to join the party! TC 7 still doesnít have it
Raman is offline
Old 10-14-2018, 08:39 AM
  #4132
OSS
How much difference is there in the new steer rack? Is the amount of play reduced enough to make it worth the upgrade?
OSS is offline
Old 10-14-2018, 12:27 PM
  #4133
Iím not aware of any new steering rack. Itís been the same since the 419
Qatmix is offline
Old 10-14-2018, 12:37 PM
  #4134
Marcika's Avatar
Hi all, in case you are interested contact me. Cheers, Marton
https://www.rctech.net/forum/r-c-ite...l#post15316830
Marcika is offline
Old 10-16-2018, 11:48 AM
  #4135
sakaguchinet's Avatar
Hi Folks,
long time no see in this Forum...
I finally made it to prepare a video, which I have shared on Youtube related to Tamiya Suspension Mounts. Despite the voice is in german I have added some english subtitles. Depending on the feedback, I am also thinking about to make more videos in english with german subtitles, as this would reach much more TRF racers around the globe.
rccartips, Qatmix, elbicho and 3 others like this.
sakaguchinet is offline
Old 10-18-2018, 10:45 AM
  #4136
I just switched to the aluminum diff cover and got the diff shims.....NO MORE LEAKING DIFF! Oh happy day!!!! I was having to rebuild my car after each race before
Nortran11 is offline
Old 10-18-2018, 11:44 AM
  #4137
nubs's Avatar
Glad to hear that!
nubs is offline
Old 10-18-2018, 06:19 PM
  #4138
Regional Moderator
disaster999's Avatar
I was only able to get 1 run before the rain came in, but Im happy to say there wasnt any leaks from the aluminum diff as well
disaster999 is offline
Old 10-19-2018, 08:54 AM
  #4139
Trader Rating: 31 (100%+)
I finally ordered a couple aluminum diff halves from overseas. I was waiting for Tamiya America, but who knows when they will stock them. I'll be on the stock plastic another weekend until they come in, but can't wait to try them and see if I notice any on-track difference.
- Jose
ittjv is offline
Old 10-19-2018, 06:27 PM
  #4140
- Jose
Which website did you ordered yours from?
