Like Tree256Likes
Tamiya TRF419
Old 04-11-2019 | 02:05 PM
  #4291
Raman's Avatar
42335 TRF Aluminum Tool Stand
42336 TRF Setting Board
42337 TRF Trolley Pit Bag
argh! Just bought a pit trolley. I wanted the Carson / Tamiya TRF one but it was discontinued so I bought a proline and then Tamiyacomes out with one
Raman is offline
Old 05-14-2019 | 09:00 PM
  #4292
Just got my aluminum chassis in and seems to be tweaked. If i put my finger down on one end the other pops up. This isnt normal right? TIA!
Gyr0 is offline
Old 05-15-2019 | 10:42 AM
  #4293
Raman's Avatar
have checked it on different surfaces?
Raman is offline
Old 05-16-2019 | 04:44 AM
  #4294
Question about the super short big bore dampers, I've been having a hard time trying to make them leak free. I've tried x-rings, shims and green slime, but nothing really works. Pressing the SSBB dampers a few times makes it leak oil, while on the other hand, my regular TRF dampers leak way less even for weeks. Also, the pistons are really small in comparison to the cylinder, giving the shaft a ton of play while the old TRF dampers have barely any play. These SSBB dampers pretty much need a rebuild for every race day.
herrokero is offline
Old 05-16-2019 | 10:49 AM
  #4295
Raman's Avatar
Replace x rings with Tamiya clear o rings and your problem will be solved.
Tamiya 53374
https://www.tqrcracing.com/shop/prod...w.asp?p_id=595
aracefan likes this.
Raman is offline
Old 05-16-2019 | 04:30 PM
  #4296
fat500's Avatar
I used 50 duro x rings in my ssbb dampers and they seeped a tiny amount right away so I figured the seals might swell .......1st race they all leaked 50 % of the oil from each shock.....rebuilt them with the standard trf blue orings and have been silky smooth and leak free ever since.
x rings
fat500 is offline
Old 05-16-2019 | 07:27 PM
  #4297
Thanks for the advice. I read these x-rings were supposed to seal better, which it obviously doesn't. I'll play around with different ways to build the dampers and post what I find since I've also got the clear and the blue o-rings. Another thing I've noticed is that middle of my oil seals aren't flat anymore and are a bit convex, likely from trying to build it with 0 rebound. I think it's making the rebound inconsistent.
Old 05-16-2019 | 10:59 PM
  #4298
rc_square24's Avatar
In my experience on the SSBB dampers, yes the kit TRF blue orings leaks like a sieve. And although the clear tamiya orings are leak free, they cause a lot of drag on the shafts.
I found that the best compromise for leakage and smoothness are the Yokomo blue orings YS7-HG. They maintain smoothness while allowing only minimal leakage compared to the others I've tried.
rc_square24 is offline
Old 05-17-2019 | 12:11 AM
  #4299
Got it figured out thanks
Gyr0 is offline
Old 05-18-2019 | 07:45 AM
  #4300
Raman's Avatar
Tamiya blue o-ring = bad O-Ring .. x ring or normal.
Raman is offline
Old 05-21-2019 | 03:48 AM
  #4301
Too early to tell, but so far I've tried putting shims above and below the x-ring, and it's getting a really good seal whilst still being really smooth. I'd say it's likely that the cause of leaking before was due to the x-rings being around 1.75mm, so there would be a big gap for the oil to leak through when using no shims. I also used a 0.1mm shim for the dampers built with either blue or clear o-rings, and they also haven't leaked, but the clear o-rings are noticeably grippier. No doubt the clear o-rings seal better but might not be as smooth.
Old 05-23-2019 | 08:39 AM
  #4302
CL's Avatar
CL
Anyone looking for an alum chassis for the 419X/XR? Let me know. I have a new one that I'm not using.
CL is offline
Old 06-06-2019 | 10:35 AM
  #4303
snopro31's Avatar
Any of us true blue believers ever done any vs type challenges ?
like 419xr vs a800 , t4 18-19 , yokomo bd9 or what ever, all you hear
is how fast people become soon as the get an awesomatix or xray none
of them ever seem to be tested from or vs a Tamiya. Has anyone tried and how was
it , does our amazing blue beast hold it’s own or are the big 3 faster?
hoping for carpet and asphalt tests
snopro31 is offline
Old 06-06-2019 | 11:04 AM
  #4304
nubs's Avatar
Juan Aveytia ran both the TRF419XR and the Xray last season. From what he told me, the 419XR could hold its own but he admitted that the Xray had superior build quality.
nubs is offline
Old 06-06-2019 | 11:16 AM
  #4305
snopro31's Avatar
hey thanks! the xray does have a nice fit and finnish type of build. , but most importantly someone found them to be on the same playing field on the track and that's what matters, hopefully someone has done some awesomatix testing that has a 419xr
snopro31 is offline
