STOCK motor forum
#2026
Originally posted by hyena boy
who makes the "f" brush?
has anyone found a good set up for the new epic handout motor? i got them at cleveland but i was not there too talk to other racers. the only thing i have found is they get hot.
#2028
I've heard that people just skim the comm with a new motor...........
#2030
Re: Comm Size
Originally posted by StewartFan20
I hear someone say they will take a new motor and cut the comm down to a specific size.
Does anyone else do this? If so, why and what size? Also what what does this do to the life of the comm?
#2031
Re: Re: Comm Size
Originally posted by Losi Will
Cutting the comm down to .275" from new will remove some of the armature's rotating weight and let it spool up slightly faster. I wouldn't bother with it unless you feel like replacing armatures every weekend.
Thanks. And that answers my next question....What does it do to the life of the arm?
Thanks again. I am new to this electric motor stuff and still learning.
#2032
Re: Re: Comm Size
#2033
Smaller comms give more torque because the brush can come into contact with more copper. So the 3 comm segments are in contact with the brushes 100% of the time. You get more power, but lose efficiency because the comm shorts out a fraction of the time. I believe. this is correct.
.270 is the smallest you should cut your comm to.
#2036
p2k2
ya thats wat i did with my p2k2 and man was it hauling!!
#2037
R/C Tech Elite Member
Hey,i run p2k2 in my tc3, I dont know what tooth spur gear i have, and im not to sure what pinion i should run, right now i have a 24 tooth in it. i have Fusion 1.183 packs to back me up.
here is a pic of my track general weekly layout, would you consider this a speed track, or a torque track what motor would you recommend /pinion,spur,brushes and springs. lol i ask alot!
Here is a pic of the motor/spur
#2039
Figure out how many teeth are on the spur, it should say on it. With that motor and track, you'll probably want a final ratio of about 6.8.
#2040
2cents
bschorr-looks like u would want more torque than rpm. the track looks little on the technical side. but looks like youre running the right motor for torque. but u can also may want to try a monster stock. my 2cents
