STOCK motor forum
#1876
Ok, that's what I thought, but wasn't sure because both names were so similar. Thanks for the help.
#1878
Originally posted by Slider
i just bought some epic replacement armatures for a couple of my older practice motors. I'm just wondering if anyone knows whether the standard replacement arms sold by trinity/epic are balanced?
I bought 4 arms and none of them has any drill balancing holes at all. They're the roar legal arms so none of them is epoxied, which I take it means they are unbalanced.
I can't see all four of them being perfect naturally balanced arms when they are sold as standard replacements not even pro spec arms.
Ive bought 3 new Binary pro motors which are epoxied balanced. But ive noticed only one is balanced and the other two are not. does this mean there balanced enough to not be epoxied?
#1879
ANY BODY USE BEARINGS IN THEIR STOCK MOTOR YET NOW THAT IT IS ROAR LEGAL?
#1881
I DON'T REALLY NOW BUT IF YOU GOT TO ROAR'S SITE IT IS IN THE RULE.
#1884
SORRY MY BAD. I WAS READING IT WRONG. ONLY BRUSHLESS.
#1886
Originally posted by ottoman
I just checked the ROAR web site and nothing is said about a rule change. Rule 5-26 says NO ball bearings in a stock motor... did I miss something?
Just upped my ROAR membership and got the 2004 Rules with an addendum sheet.
Per the Rules Correction to 5-49, ball bearings only applies to 19T "Super Stock" which some people seem to call "Stock" in some areas of the US.
#1887
I REALLY WANT TO BUT I'M GOING UP NORTH WITH THE WIFE. I THINK TAHT STAN IS COMMING. I WORK SOME SUNDAY SO I WILL ENVENTUALLY GET OUT THERE.
#1888
When narrowing brushes for more timing, do you tack from the leading or trailing edge?
#1889
Trailing for more rpm, leading for more torque.
#1890
Bearings are not legal for stock, it specifically says all 27t stock motors must be bushing motors......
However, its a stupid rule, since bearings are so cheap now.....all it would do is save racers money by allowing bearings in stockers, not to mention it would make tuning a stocker MUCH more simple.
Later EddieO
Later EddieO
