New Novak Brusless System
#1865
where do you folks suggest buying a 4.5 system from for shipment to the UK?
#1866
I'm on Spain and every Novak stuff I once bought was from tower... they have now a discount of US$30 for international shipping... at for such a small item, shipping is no more than 18-20 bucks (airmail)... for me, makes a lot of sense. PM me if you want the discount code.
cheers,
al
#1867
Hello,
Does anyone know what the different profiles are on the GTB?
#1868
Super Moderator
Originally Posted by MoonTrap
Hello,
#1869
Originally Posted by UN4RACING
Pull it apart and see if its shorted. Did it smell? If the coating on the winds are melted it may have shorted. It will run but stuttered. If its in the can its shot. Stomp on it and throw it away. As far as thermol protection, thats electonics. And that avatar makes me want one. Later dude let us know.
As far as I can smell, nothing is shorted with the esc or anything in the motor. I just bought a rotor from MarcosJ. I'll let you guys know the outcome when I replace the rotor. Thanks again for the advice!!!
#1870
Guys I need some input.
I basically destroyed by trans cap on my gtb (came off the double sided tape and scrapped on asphalt). I have ordered a replacement by it will take a while. So, my question is can I temporary substitue it with an aftermarket cap? Will an aftermarket cap effect the esc in anyway?
#1871
you can buy one from any electronic stores. just make sure that it has the same microfarad usually 4700uf, regarding the voltage (10v is fine or 16v). I installed one in my esc at it works great. some say that you should choose capacitors with low esr but any capactiros will do the job just fine.
make sure to connect it properly, or you'll blow that capacitor. I blow one before and man it was smooking scary..
#1872
Thanks Marcos
However i was wondering as to the throttle profiles of the GTb, which one is less punchier than the rest ?
#1874
Thanks Marcos
And what is dead band, is that like neutral width on a keyence ?
#1875
when your motor gets hot does your car just stop?
