Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-08-2016 | 01:21 PM
  #826
Josh L's Avatar
Originally Posted by IndyRC_Racer
The HPI Vintage wheels are designed to be used with the HPI Vintage tires. If your local class has a spec touring car tire, they most likely won't be able to be mounted on the HPI Vintage wheels.
HPI does make a 26mm "stock car" wheel in black that is designed for standard touring car tires. The part number is 3741. Here is a link on Tower (http://www3.towerhobbies.com/cgi-bin...?&I=LXNV38&P=7)
You pose a good point. I will have to consider this and ask them what the rule is on tires before I choose something.
Josh L is offline
Old 02-11-2016 | 12:31 PM
  #827
Default Racing a tt-02 type s in the TCS?
I was looking through the Tamiya Championship Series rules and I don't see a class where this variation of the car could be competitive. I was thinking GT Pro spec, but the type s is not allowed there. Can anyone think of a TCS class where this car could be geared/motored competitively?
microed is offline
Old 02-11-2016 | 06:42 PM
  #828
Tires must be a tamiya kit tire rather it be a slick radial Hal slick half radial an must be 26mm
bryangrizzlyohi is offline
Old 02-11-2016 | 07:10 PM
  #829
Tires are not the problem. It is more of an issue of getting the gear ratio down into the 3.5 to 4.0 FDR for a brushless setup without using non-Tamiya parts which is not allowed according to TCS rules. Of course you can run a silver can 540J in the gt3 class and gearing won't be an issue, but you will need to run against others chassis with 21.5 brushless motors. There is no way a 540J motor is anywhere near the speed of a 21.5, a 25.5 maybe, but not a 21.5.
microed is offline
Old 02-12-2016 | 12:48 AM
  #830
I managed a FDR of 4.35 without any mods. Assuming you do not have to use Tamiya Spur gears you can do this.
http://www.thercracer.com/2013/07/ho...inky-with.html
Qatmix is offline
Old 02-12-2016 | 12:30 PM
  #831
Thanks, but 4.35 is not going to be low enough for the track and motor I will be running. I had the motor I am going to use in another car and a FDR around 4.0 seemed to be about perfect for it. I am guessing I would need a YR motor mount to get that low? If so, it would not be allowed according to TCS rules.
BTW, I saw your site and you have some great info on it about the tt-02.
microed is offline
Old 03-01-2016 | 10:35 PM
  #832
just bought a type S after the shops restocked it then i remembered my dilemma last time
type R has a 3degree toe in rear hubs as standard and type S only has a 2.5degree toe (as an aftermarket option) but the type S also has a 3degree toe in in the form of a steel suspension kit?
so if i used that suspension kit on the type S, would i get a 3 degree toe in, similar to the type R?
I bought the type S because i couldnt find it last time to i took the type R and now I am wondering if i should sell it or keep in/built it.
novaris is offline
Old 03-02-2016 | 11:12 AM
  #833
If you use the 54634 rear steel mount it will increase the Type S rear toe by 0.5 degree to give 3 degrees. The main point of that mount though is to allow you to fit the rebound stoppers which then allow use of the droop screws. I fitted this to my Type S but IMHO it made the car much worse to drive as limiting droop caused the rear end to break away off power into corners. So any advantage the extra .5 degree toe gave was wasted. My Type S is lovely to drive on standard settings. I just hopped up other parts instead.
Mini35 is offline
Old 03-03-2016 | 08:40 PM
  #834
so the steel part only gives an additional 0.5deg?
the description is quite misleading "Rear plate gives a setup with 3 degrees of toe-in for excellent stability. "
novaris is offline
Old 03-21-2016 | 08:59 PM
  #835
BadSign's Avatar
Anyone using the 54574 aluminum steering links, and if so, how do the attach? Is there a nut to hold them under the chassis? My existing tub is stripping out after only two nights of racing.
BadSign is offline
Old 03-22-2016 | 02:22 AM
  #836
The hop up TT02-S steel rear plate gives you 3 degrees of rear toe-in.
The TT02-S has 2.5 degrees of toe in with the rear plate that is included.
A std TT02 has 0 degrees of toe in. Unless you buy the hop-up rear hubs (they give you toe in at the rear of 2.5 degrees) or if you buy the TT02-S hop up suspension set which gives you 3 degrees.
As a side note, the hop-up suspension set also allows you to add droop limiters to your TT02-S which makes things easier.
Sorry no, they just replace the plastic part, there is no nut to go under the chassis. How have you damaged that part of the chassis? You didnt use threadlock on the parts or an electric screw driver?
Qatmix is offline
Old 03-22-2016 | 05:44 AM
  #837
BadSign's Avatar
No, I took a big hit and snagged the wheel. It pulled the screw most of the way out.
BadSign is offline
Old 03-22-2016 | 06:34 AM
  #838
Ouch!
Luckily the replacement chassis are very cheap, it's just a pain taking it all out
Qatmix is offline
Old 03-22-2016 | 10:41 AM
  #839
Been there, done that. In my case I used the low friction hop up screw and it sheared the top clean off leaving the thread in the chassis.
Mini35 is offline
Old 03-23-2016 | 09:46 AM
  #840
Here's my TT-02D Type S that I race at the local Tamiya Series. Handles great, although it's not quite as nimble or quick to react compared to my TA05v2 that has the same servo and motor/esc combo. Any ideas on how to make it quicker to respond to steering inputs?
breyton is offline
