Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-13-2016 | 05:45 PM
  #856
Had my first drift around the street this evening. Slides beautifully with awesome control. I don't have to worry about the bumper skid slamming into bumps and rocks at high speeds or the body dragging the pavement. This is great fun!
I had to add a few strips of body foam to the existing foam bumper to support the long Lambo nose but it worked out perfectly. I sealed all the foam strips together with a thin bead of UHU-Por foam glue so I don't have to worry about them separating over time.
I think I have enough wheels and tires for it now.
Attached Thumbnails Tamiya TT02 Thread-img_6089.jpg   Tamiya TT02 Thread-img_6098.jpg   Tamiya TT02 Thread-img_6099.jpg   Tamiya TT02 Thread-img_6100.jpg   Tamiya TT02 Thread-img_6101.jpg
Metal One is offline
Old 04-14-2016 | 07:58 PM
  #857
SuperFastSnail's Avatar
Originally Posted by ic-racer
Were you able to get a big enough pinion that you did not have to cut a hole in the pinion plastic cover? I'm running a 50T on my VTA TT02-S spec.
I'm just currently experimenting with 48 pitch gears right now because I have a lot of them laying around. The bigger gears would take the punishment better but would lose gear ratios dramatically compared to the 64p gears.
SuperFastSnail is offline
Old 04-14-2016 | 09:50 PM
  #858
Just a couple pics tonight. Mirrors came in today. 6 sets on a sprue and not one set fit like I wanted them to. This was the closest. I'll keep looking but it's close enough to call it finished now.
Attached Thumbnails Tamiya TT02 Thread-img_6148.jpg   Tamiya TT02 Thread-img_6143.jpg
Old 04-15-2016 | 07:48 AM
  #859
Very nice Lamborghini!! I found some aluminum tape for ductwork at the hardware store. It sticks well (as well as servo tape), it is light weight and conforms well to just about any surface. It can be used to block the stray light from the back of the buckets.
ic-racer is offline
Old 04-15-2016 | 09:08 AM
  #860
firefoxussr's Avatar
Maybe one of you can advise me on this- I have a regular TT02 (not S or R) with a recently broken rear a-arm.
Can I just use a #53928 short reversible on a standard TT02? It looks like that's what is used on the TT02-S.
Never mind, think I found my answer here:
Last edited by firefoxussr; 04-15-2016 at 09:24 AM. Reason: didn't google hard enough
firefoxussr is offline
Old 04-15-2016 | 09:48 AM
  #861
Yep, it's a bit costly but the handling difference is really noticeable.
The steel conversion parts allow you to add the down stop parts which the actual TT02-S kit parts do not.
Qatmix is offline
Old 04-25-2016 | 03:04 PM
  #862
eR1c's Avatar
I have a few questions about the TT02 (sorry if they are answered in the 50+ pages of posts).
I race cars w/ a club and have for years. I realized I don't own a car that I can enjoy on regular pavement. All my cars are super low to the ground, and have open gearing (F1 and TC 17.5 are two of my racers) -not exactly parking lot friendly. I have been looking for something that is inexpensive that I can just have some fun w/ in the driveway and at the local park. I want it to be closed gearing as I don't want rocks chewing up the gears. I have been looking at the TB04, -but at $200 for the kit I just don't care to spend that money. Don't get me wrong I've spent thousands on my race/club cars ...but for parking lot fun I don't care about precise split second control and honed in torque and rpm. In fact I don't plan to race this at all ...just something to play around with. So I keep going back and forth w/ the TB04, but then saw the TT02S. I can get the TT02S for like $120 w/ coupons and shipped.
How do you like the TT02 ? I get that there will be some things i'll want to upgrade and I have several extra motors laying around and electronics ..i'll probably put a 21.5 brushless in this. How is the TT02's steering -does it handle well? I do own a few M05s which I race ..I get that I may have to put aluminum steering in and some good cv joints ...but will it stay planted in a straight line once you get it all sorted out?
Anything I should know about the TT02s? Is it a decent car for parking lot fun?
eR1c is offline
Old 04-25-2016 | 04:49 PM
  #863
I have had my tt-02 for about 3 months now and I think it would be the perfect car for what you wish to do with it.
I have been racing for over 20 years and I recently raced it in a Tamiya TCS race and was easily running mid pack with it in the GT-2 (17.5 motor) class. I suggest buying the tt-02D type S kit. This drift kit comes with a few aluminum goodies in the kit, including the aluminum prop shaft which is a must have if you want to put a motor with any power in it. You will need to buy some tires suitable for parking lot driving unless you want to use the drift tires. The only thing I upgraded from this kit is CVD's for the front which I think is a must have. The dog bones are fine to use on the rear of the car.
microed is offline
Old 04-25-2016 | 04:53 PM
  #864
eR1c's Avatar
Thank you!
Yes, I was planning on the TT02 "s",
you say the drift kit, -I have no desire to drift, ...so the tires would not be used, but I have a ton of spare tires from other cars. So w/ the drift kit, is there any difference w/ the setup that I should be aware of? Or is basically the same as the "s" kit (minus the extra aluminum goodies you mentioned)?
Yes, I too have been racing,, since about 2008. I have expensive cars, this one would just be to have fun building and some parking lot driving.
eR1c is offline
Old 04-25-2016 | 07:53 PM
  #865
It should be a pretty great car for what you want. It's cheap. It's tough. Most importantly, it's fun! It's got some nice upgrades available for it too. I have only used mine for drifting but I run (and drift) in some pretty rough spots. There isn't a street or parking lot in Tennessee that doesn't have small rocks, gravel, dirt and other crud ground into it and I need a car that can deal with that and not get jammed up by said rocks and gravel when the tires kick them into the chassis tub. So far so good with my TT-02D Type S.
My aluminum motor mount, shocks and CVDs should be here tomorrow. I also ordered the LaFerrari body to use with regular tires. We're gonna see just how fast she'll go on 3S very soon. I don't mind mangling a Ferrari, not that I intend to but stuff happens at 60 mph and I can get more Ferraris. Lambo bodies are a bit harder to come by these days.
Old 04-25-2016 | 08:00 PM
  #866
Thank you!
If you build it per instructions, you will be fine for parking lot bashing except for the shocks. I would build the shocks with the 1 hole pistons and maybe use something like a 50 wt rear and 70 wt in the front for the shock oil. Just ditch the tires, but the rims are fine and will work with standard 24mm touring car tires. For the front diff, use the thick anti-wear grease that comes with the kit, but I would use some thinner silicone grease for the rear diff.
I have many cars too as I really enjoy racing. However, I don't have big money to spend on RC so this car fits my needs perfectly.
microed is offline
Old 04-25-2016 | 11:07 PM
  #867
The tt-02s Drift just comes with the aluminium prop parts that the basic type S does not. You could sell the drift wheels and tyres if only racing or just keep them and have a slide every now and again.
I like the yeah racing motor mount and the speed gear set as then you can gear the TT02 with 64dp or 48dp gears and get lower fdr's
It's a cracking car, despite having a slew of race cars I still enjoy taking the TT02S to the track, it handles well.
If running on a car park I would personally go for 3 holes and full rebound with 350 or 400 oil
Qatmix is offline
Old 04-26-2016 | 07:35 AM
  #868
eR1c's Avatar
Thanks guys,
okay, will get the tt02d type s, -its only like $100. Yeah, I may sell the tires as drifting doesn't really interest me. Once I get the kit i'll let you all know!
eR1c is offline
Old 04-26-2016 | 09:03 AM
  #869
The thing I like best about my tt02's that I have is I don't worry about any of my kids or friends if they want to try a RC car out I just hand over the remote. Handles great outdoors on asphalt with cheap kit tires. Only parts I've had break is the steering rack parts.
76jimmy is offline
Old 04-26-2016 | 03:55 PM
  #870
eR1c's Avatar
-Ha, I was thinking the same thing!
I just ordered the TT02D type s
...looks like its the same as the TT02s minus the ESC, but comes w/ extra aluminum bits. I have at least 3 esc's that I am not using ...I may even keep the silvercan in it. I really don't care about making this a super fast car.
eR1c is offline
