Tamiya TT02 Thread
#2656
Both the TT02 RR and SR are discontinued... Im sure there will be something soon...
#2658
currently working on my tt02 made out of leftover parts of my TT02 type S...
now I try to build active rear but not sure if I buy RR (#54874) parts for camber control or use turnbuckle shaft and left over part.
anyone done this before? (I m sure! but cant find pics and info)
#2661
https://www.thercracer.com/2014/07/t...ar-camber.html
and for the TT-02 front
https://www.thercracer.com/2014/11/t...er-caster.html
#2662
Here is a website for Tamiya stuff that has a TT-02 rear camber mod that you might be able to do some of your existing parts.
looking more for Tamiya Cup Racer
#2664
thanks for the help!
#2665
Hello, of all the aftermarket companies out there that make stuff for the TT02 platform which is the best one to go with?? I'm looking for the best fitment, durability, blue color, etc?? I know there is yeah racing, gpm and a couple others. I'm looking for the closest to tamiya quality without the tamiya price. Lol. Thanks
#2666
the stock dampers with 2 holes and 400 cst oil looks hard to me (normal I drive the TRF), I think I go much more softer and lower, first I change springs...
Currently I like the look of the car but I`m not sure if I keep it or sell it.
#2667
Just curious about this diff. I noticed that it only comes with 1 cross shaft and 2 spider gears. But the cross shaft has a flat spot in the middle, and the diff case has a slot for possibly another cross shaft.
Is it possible, or is there any advantage, to adding another cross shaft and 2 more spider gears? That gives it essentially double the gear surface area just like the stock TT02 differential but sealed.
Just wondering cause I’m pretty happy with my front one-way and rear stock diff stuffed with anti wear grease.
#2668
if you try something diffrent share it pls!
best and good luck
1386Likes
