Tamiya TT02 Thread
#2627
I just revisited thercracer site and checked the article.
The author mentioned a ride height of 5mm front and 5,2mm rear, but not how these are achieved. He is using the 42102 TRF shocks, but no indication which spring or other settings are needed to get there. So, maybe you are kind of misguided at the moment?
using 42102 TRF dampers, with standard length spring, no way I could get 5mm & 5,2mm ride height
Changed the using short springs (for M chassis dampers), yes... got the ride height.
#2628
Just came across this oil filled differential kit made by Yeah Racing. https://www.rcmart.com/yeah-racing-o...t-020-00104972
Wonder how well it works compared to the one made by 3racing and the Tamiya one.
#2631
Has anyone successfully stretched out the suspension to accommodate a 210mm body (Yes its 210, not 200, its a Kyosho Ferrari 575 GTC LM)....?
The widest I have managed to get my TT02R thus far is 190mm using the 50808 long axles.......
I'm trying to avoid using the 12mm wheel hex hub adapters because then the geometry gets really funky...If there is a way to extend the suspension...I'm all ears.
Any one attempted this experiment already?
#2632
#2633
Those files aren't up to my standards, but thats the direction I'll take. I'll draft them myself and find some suitable length driveshafts....
#2635
I've been parsing through lots of information in the process this week of setting up my first TT-02. I've updated the Wiki at the top of the page with much of the general information. I'll continue as I learn. Hope it helps some other new guys get the info a bit quicker. See you guys on the track.
#2636
thanks
#2637
Hi, new to the forum
. Just saw tamiya's 2021 releases and saw tamiya is releasing a tt02 on tracks
. Item: 58690 Landfreeder Quadtrack (TT-02FT) Looks like it uses stock arms but replaces uprights with new ones. Also seems to come with a lexan chassis cover, first official cover by tamiya since the tb01? I spy friction dampers too
. I have also got a tt02 to show you all, but have to wait untill I can post pics, since this is my first post.
1387Likes
