Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-07-2020 | 04:19 AM
  #2251
Suspended
Just bought a TT02RR from RCJAZ for $206 Australian and after downloading the instruction manual I've noticed that it doesn't come with silicone diff oil for the front and rear sealed diffs.
What do you guys recommend as starting point for front and rear diff oil weights with a 10.5-8.5T motor?
Pablo17 is offline
Old 01-07-2020 | 01:14 PM
  #2252
chucko's Avatar
Originally Posted by Pablo17
Just bought a TT02RR from RCJAZ for $206 Australian and after downloading the instruction manual I've noticed that it doesn't come with silicone diff oil for the front and rear sealed diffs.What do you guys recommend as starting point for front and rear diff oil weights with a 10.5-8.5T motor?
if you want it to lock for drifting use 125.000 oils or if you road race and want better 4 wheel traction,... just use grease.. these diffs are not oil friendly they leak if you use 7000 or any thing less
Pablo17 likes this.
chucko is offline
Old 01-07-2020 | 06:57 PM
  #2253
Default Getting back after a really long time
It's been 15 plus years since I have had a RC car. I just started back and picked up a tt02 Audi and would like some information on upgrades and running on lipo. I have picked up 2 trucks over the summer and they run on 3s so I have 5 packs and only one 2 s
Grnjetta6 is offline
Old 01-08-2020 | 06:35 AM
  #2254
Originally Posted by wtcc
I kicked off the indoor season for myself today. With the upcoming Tamiya Euro Cup race in mind, I brought the TT-02s to the track. The track got new carpet and a new layout. I found a decent rhythm quite fast, but had to fight a little with the car. The rear was stepping out suddenly. I tried a lot of things without effect. Later in the day a little less droop and a reduction of the steering angle helped this problem. I then cured it by taking out 1mm of the rear inner camber link shims After that I could increase the steering angle again and finally got some consistent runs
By the way: Has anybody already driven the new Ford Mustang? Does it have a good performance?
I would like to see photos from the back of the car
​​car because I want to see what you did with the rear bumper mount. Did you cut it?.....By the way, I loved your car, I am looking to build one exactly as yours.
Wascheck is offline
Old 01-08-2020 | 10:46 AM
  #2255
wtcc's Avatar
Thanks! I just do not use the rear bumper mount.
wtcc is offline
Old 01-08-2020 | 12:03 PM
  #2256
Since I built that TT02 a month or two ago, I've been pondering a few things.
First, has anyone come up with a good droop solution for either the stock, or S type arms for the TT02? Second, are there any swaybars available? I don't see either.
Nerobro is offline
Old 01-08-2020 | 12:17 PM
  #2257
Raman's Avatar
The S arms have optional adapter for droop
Raman is offline
Old 01-08-2020 | 12:22 PM
  #2258
Raman's Avatar
This is what you need
https://www.tamiyausa.com/shop/optio...eel-sus-mount/
https://www.tamiyausa.com/shop/optio...l-sus-mount-2/
2x this
https://www.tamiyausa.com/shop/optio...bound-stopper/
Raman is offline
Old 01-08-2020 | 01:40 PM
  #2259
Well that covers droop. (I"m amused that the descriptions do not do them justice..) Swaybars?
Nerobro is offline
Old 01-08-2020 | 02:16 PM
  #2260
Raman's Avatar
Ahhh now you want sway bars sheesh man ... what’s next the shirt on my back lol.
Tamiya has yet to make sway bars obviously. I believe our friend Qatmix worked on something but not sure if it’s available for sale
Raman is offline
Old 01-08-2020 | 08:07 PM
  #2261
well, what do you expect from me? :-) Before I go nuts figuring out my own solutions.... I've got a few ideas. It's amusing how far this platform has been taken by tamiya themselves, yet...
I mean, there's the TT02 RR, which gets you adjustable camber, sealed oil filled diffs, an aluminum driveshaft. The TT02 Type S, has "modern" suspension. Hard and soft tub choices. Then there's cars that go all the way down to soft tub spring damper setups.
And then, it's sold as a off road buggy too.
I find it an interesting platform. I'm suprised "basic" racing features, aren't common on it yet.
Nerobro is offline
Old 01-09-2020 | 04:08 PM
  #2262
I’ve had roll bars for over a year or so for the typeS also got a design now for std TT02’s.
i will pop them on shapeways
Raman, Nerobro and CTE like this.
Qatmix is offline
Old 01-10-2020 | 05:46 AM
  #2263
I wonder when we will see more info on the coming SR. Would be really cool to see it use 420 suspension...
Qatmix, do you know anything of it yet?
GimpyGolden is offline
Old 01-12-2020 | 08:33 PM
  #2264
I picked up a new TT02 EuroTruck and after maybe 8-10 runs (over a few weeks) the power just completely cut when I was driving (no steering or throttle). Now when I turn it on the esc blinks green and beeps twice, small pause, and then continues to blink green and beep. No power to steering or throttle. Seems like a fried esc? Just strange since the car wasn't run hard and it's the stock esc/brushed motor. Anybody have this problem or know the issue? I sent a message via Tamiya USA website, but they never replied. Thanks
nomoscrilla is offline
Old 01-12-2020 | 08:36 PM
  #2265
The EuroTruck is a TT01e. Though your problem is with the ESC/Reciever I believe. I beleive your reciever lost bind. Re-bind the reciever.
Nerobro is offline
