Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1386Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 12-20-2019 | 12:25 PM
  #2221
Originally Posted by SteveM
The Gravity USGT tires are 24mm while the kit supplied rims and tires are 26mm. Looks a bit better with the kit tires.
That did it!
Seth
SteveM likes this.
sethwas is offline
Old 12-26-2019 | 11:12 AM
  #2222
Just completed a TT02 rally build today. I havent been into RC cars in a long time. Most of my last 10-12 years of RC has been helis and planes.
I cannot believe how much slop is in the front suspension and the lack of bearings, turn buckles, etc. I have ordered a bearing kit. I was looking at the hop-ups to bring this chassis into a respectable track car. Looks like you have to put about $200 into the base kit. Is that right?
If I am going to do that I should have just bought a high end racer $450-600 to begin with. Am I wrong here? Like I said no RC cars in the last 15 or so years. I do remember I had HPI RS something that was tight out of the box years ago.
electricdurango is offline
Old 12-26-2019 | 11:17 AM
  #2223
Built box stock there is substantial slop, but it can be shimmed out if you are patient for relatively little cost. Bearings are a must and it amazes me that Tamiya still sells these kits with the white plastic bushings when a full bearing kit costs as little as $7 anymore. At least they could include the bronze bushings.
The cost to make the TT-02 a tack capable car is high and it will never compete well. There are so many other 'entry level' sedans out there that are far superior that it makes no sense to spend $$ on upgrading the TT cars.
SteveM is offline
Old 12-26-2019 | 01:47 PM
  #2224
This will have to become a basher for the front culdusack when the kids are playing out front. The only tracks in my area within an hour are clay off road for buggies and trucks. Seems like the 15+ years I have been absent from the car game all the local tracks have vanished.
Old 12-26-2019 | 03:10 PM
  #2225
If I had my time again, I would have bought an Xpress or something to start out with.
SteveM and Nerobro like this.
Bloke is offline
Old 12-27-2019 | 11:22 AM
  #2226
Not really - if you add Tamiya 54752 you should be ok to go for your steering concern.
I assume your kit has adjustable shocks so you can mess with spring rates and fluids so no extra money here.
Want to firm up the tub for tighter steering response, they make an aftermarket carbon brace and that's $20 but not needed for rally.
If you want to lower the FDR you get the high speed gear set for $10. All in you're at maybe $50 and done.
If you really want to go faster, you need to find a non-tamiya motor mount and large pinion, but this is probably overkill for rally too.
Otherwise, you 'can' get the aluminum prop shaft and joint, it won't make you faster, but doesn't wobble like the stock one at higher speeds. Same with changing any of the non-adjustable parts for their adjustable options. These things usually are stock on the R and RR (and to a lesser extent D).
The $200 number you saw was probably for appearances stuff (aluminum and carbon all the things!) but don't really impact performance at this level.
As others have mentioned, the TT02 is good for spec racing, or racing at lower speeds. It is objectively an excellent racer, just not in every class under the sun.
If you want to do stuff in 17.5 TC, or USGT, it's not the chassis for you because at that level being able to tweak every little thing is important and the 02 doesn't have that ability without substantially changing lots of parts. Not saying it can't be done, but as others said, it ends up costing more than a basic kit from another brand.
Seth
sethwas is offline
Old 12-27-2019 | 03:45 PM
  #2227
I'm with them. Save your money and just enjoy the TT-02 as a backyard Rally car. I wouldn't put any money into it. Pick up an Xpress, a Sakura or better, if your budget allows, and hit the track with that.
- Jose
rippen likes this.
ittjv is offline
Old 12-28-2019 | 07:31 AM
  #2228
proliteandsc's Avatar
TT-02 is a good car for a hobby store to use to get new people on the track. The low price and lack of adjustability makes it easy to get into racing. Newcomers are not overwhelmed by the endless adjustments most other cars have. This gives rookies a much better chance to win with little practice. It's one of a few classes of racing won on the track and not the workbench.
This is a low cost entry level car, made more for bashing, so your going to get slop. A lot of people that buy RC cars use them 5 or 6 times and that's it. Plastic bushings fine for that. Get the bearings if your one of the few that races it in a TT-02 class or want more use out of it. This car will need some money if you want to race it against X-ray, Shumacher, or Associated cars, and you will be at a disadvantage. Those cars are made for racing.
angrymelon likes this.
proliteandsc is offline
Old 12-28-2019 | 07:52 AM
  #2229
MD's Avatar
MD
I think the TT02 with bearings is a good car. One of the problems we have in r/c racing is the thought that we all need one of the top and expensive brands to have fun racing. I think that if we want to draw more people to r/c racing is that we have a less expensive class to race in. The Euro Truck is an example of a class rules that should be applied to other classes. The EuroTruck Class is good, but the bodies are too expensive. In some places the run a "TT" class with then same basic rules as the Euro Truck with the exception of tires and bodies of course.
MD is offline
Old 12-28-2019 | 07:59 AM
  #2230
Exactly. The key word is "Fun" and the TT-02 kit can provide lots of inexpensive fun for anyone looking to try on road racing. My club, along with a few others in the area, are trying to start a TTGT class using the base TT-01 and TT-02 chassis. No SS or R models, just the base versions. We've set rules as follows;
PROPOSED Rules for TTGT (Spec class)
CHASSIS: stock TT01 / TT01E or base TT02 / TT02SE ( B/D/T/S/R/RR variants NOT permitted)
ESC: "Box stock" Tamyia ESC as delivered in the OEM box
TIRES: Gravity Racing USGT tires on styled spoked rims
SERVO: Open (servo saver may be added)
BODY: Scale Tamyia Sports car bodies only, no TC, Prototype or Stock Sedan style bodies
WINGS: Molded plastic and only what came in the kit - no non-OEM wings may be added
MOTOR: Tamyia brushed Silver can 540 Torque Tuned motor ( for the initial run this season for the class whatever motor that came in the kit may be run )
BATTERY: Lipo 2 cell, 8000 mah Max
Only Allowed Modifications
  • Hex screws may be used in place of the OEM Tamyia screws
  • Nylon bushings maybe replaced with ball bearings
  • battery connectors may be swapped for Deans or other type connection
  • Round Lipo batteries are preferred However - Chassis ribs may be removed to allow a standard rectangular Lipo batteries to be used ( will allow racers to use batteries they may already have keeping costs down)
MD and angrymelon like this.
SteveM is offline
Old 12-28-2019 | 08:45 AM
  #2231
Raman's Avatar
The spirit of RCGT lives on! I’m happy to see this!
the day USGT opened the doors to PF bodies was a Pandora’s box. Now PF, Bitty, Monetech, McCallister, Exotek are all making “lookalike” bodies.
Raman is offline
Old 12-28-2019 | 08:51 AM
  #2232
Raman's Avatar
The only changes I would add is functional Hop ups that would allow durability, like the TCS Spec Novice
Speed Tuned Gear Set
Aluminum motor mount
Oil-filled dampers
Alu centre prop shaft
Raman is offline
Old 12-28-2019 | 09:46 AM
  #2233
...and racers are spending hundreds, if not thousands of dollars, on top-line sedan chassis just to compete in what was to have been a more sportsman type of class.
SteveM is offline
Old 12-28-2019 | 09:58 AM
  #2234
MD's Avatar
MD
That's great! Some us can remember when the Slash first came out and all the fun we had in the Slash stock class, When everyone had to go faster, handle better, etc., it disappeared in our area. I hope you have great success and others will copy it.
SteveM likes this.
MD is offline
Old 12-28-2019 | 10:34 AM
  #2235
Oil-filled dampers
Allowing these upgrades defeats the purpose and intent of the box stock class and I would discourage anything like this. Leave the cars as stock as possible so that everyone has the same opportunity to succeed. It's tough getting younger kids to stop playing Nintendo Switch as it is, no need to open Pandora's Box by allowing upgrades. The Tamiya Truck class is fun and no upgrades allowed other than bearings.
MD likes this.
SteveM is offline
