Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 12-05-2019 | 03:25 PM
  #2206
Raman's Avatar
Soon to be released 47439 1/10 TT-02 Type-SR Chassis Kit? Swap bars please!
rippen and Nerobro like this.
Raman is offline
Old 12-11-2019 | 10:08 AM
  #2207
proliteandsc's Avatar
Hope it's the type s with useful upgrades that will help racers.
rippen likes this.
proliteandsc is offline
Old 12-11-2019 | 10:19 AM
  #2208
Default Need VTA setup for TT-02 s
Looking to use a TT-02 Type-S in VTA. Anyone have a setup I can start with or know where I can find one? I'm racing on a very small asphalt track.
Old 12-11-2019 | 11:24 AM
  #2209
f1larry's Avatar
Yes hopefully this is just a R version of the S and comes with all the aluminum upgrades the regular R or RR come with. If so this will be the Pro Spec setup to have.
f1larry is offline
Old 12-11-2019 | 11:55 AM
  #2210
If you are talking about the Tamiya TCS series GT Pro Spec class, I doubt the SR will be legal if it's based on an upgraded S chassis, as the rules for that particular class specifically exclude the TT-02S. At least in 2019...
https://www.tamiyausa.com/media/file...s-962-a4df.pdf
If you are referring to a different series, ignore me and carry on.
Helios is offline
Old 12-11-2019 | 12:02 PM
  #2211
f1larry's Avatar
Yes you are correct, I forgot they allowed the S in the Novice Spec class but not the Pro Spec class.
NutDriver likes this.
f1larry is offline
Old 12-11-2019 | 12:12 PM
  #2212
All good. The only reason I knew about it was because I was just looking at maybe building something for that class (and eyeballing an R).....then I went and got stupid and pulled a trigger on an TB Evo.7.....because I needed another standard TC . Will probably look at an R again later in the winter if it looks like I'll have time to race w/ some of the guys down south that run a TCS style class structure (including Pro Spec) next summer. I just tend to get super busy over the summer w/ road trips and bike riding that RC typically takes a back seat until winter when the weather is less than ideal outside.
Helios is offline
Old 12-18-2019 | 05:12 PM
  #2213
I just picked up this TT-02 Mustang GT4 from a chap who had a change of plans. The body came painted but I had to add the decals. Looks OK and should be fun for my club's proposed TTGT class that calls for stock TT-01 / TT-02 with the silver can motor but USGT tires.
SteveM is offline
Old 12-18-2019 | 09:41 PM
  #2214
Looks familiar Steve, mt GT4 was also painted in Corsa Grey.
If you can make the trek we race TT here in Vaughn at Phoenix RC as well. Next Trophy Race is Race 3&4 of Phoenix Cup. January 19 and February 23
SteveM likes this.
GimpyGolden is offline
Old 12-19-2019 | 07:04 AM
  #2215
It's such a nice color.
Looks like the offset of those rims tucks the tires under the body.
If you can run the 'wide' axles (if your rules allow) it will flush the rim to the side of the body.
I had the same thing happen with some other tamiya bodies that are more of a 190mm width for the 186mm width chassis. I'll see if I can dig up a photo.
Seth
sethwas is offline
Old 12-19-2019 | 08:35 AM
  #2216
Seth
The wide axles are not included in the kit, and as we are running a box stock class I doubt that I can use them anyway.
SteveM is offline
Old 12-19-2019 | 12:00 PM
  #2217
really? I didn't know that.
They wide axles are on the standard 'C parts' tree.
Seth
sethwas is offline
Old 12-20-2019 | 05:17 AM
  #2218
Seth
The manual has the axles greyed out with the note of "Either Rear Wheel Axles C3 or C6 are included." with the C6 being the long wheel base. Tamiya must adjust the kits depending on version to include different axles.
I do have two center shafts and two A5 steering parts though along with the motor mount for a 380 Mabuchi motor.
SteveM is offline
Old 12-20-2019 | 05:25 AM
  #2219
Seth
The Gravity USGT tires are 24mm while the kit supplied rims and tires are 26mm. Looks a bit better with the kit tires.
If I add a 1mm wheel spacer and use the serrated wheel nuts, the Gravity RC tires move outward slightly and look better.
rippen likes this.
SteveM is offline
Old 12-20-2019 | 06:02 AM
  #2220
Use the kit wheels/tires on the shelf. On the track run what works... USGT Premounts.
Myself and a Buddy have tried USGT Tire on kit 26mm +2 offset wheels and they just don't work, car is stupid loose.
With the narrow track width it runs much faster and is easier to drive.
