Tamiya TA05 Touring Sedan
#1246
TRF 49355 Shock parts
I am having a bad day. I set out the parts to build the shocks yesterday. When I started on my 2nd shock today, I accidentallly spilled the metal parts bag and everything scattered everywhere. I think I found everything, and I finished the shocks. But looking at the extra parts, I found 4 extra E-clips. The problem is that I am not sure if I put away all the TA05 parts before I opened up the shock kit. Did these parts come from the shock kit or did I have some parts out from the TA05? This worries me. If I had extra parts from the TA05 out, I have no idea whether I have actually lost parts or not.
Did anyone else who built these shocks have extra E-clips left over?
#1248
I had one or two extra e-clips if I remember correctly. So nothing to worry about. Just check the car if everything is attached correctly. Other than that you should be fine.
Alwin.
Alwin.
#1249
How many of you guys drive the TA05 on unpaved roads? Like ones where there are sticks and stones around? And how many have had to replaced diffs or belts because of sticks and stones chopping it up?
#1250
#1252
you guys know if tamiya will release a carbon upper deck? im thinking of getting one from tech racing but i prefer to get tamiya only hopups (in the hope of someday joining our local tcs ) however, if the tamiya upper deck is months away, ill get an aftermarket one thanks for any info
#1253
Suspension Hop-up options marked as "HARD" what does it actually do? Does resist flexing more; therefore is it good for carpet? if it is then, is there a HARD suspension arm and front C-hub?
TNX for all the help
#1254
Yup, they're made of the same material as the TA05 chassis, the "Fibre-reinforced" Polyamide, as opposed to the regular plastic. They're stiffer, and more resistant to breaking. They have arms, front and rear uprights made like that. The 2-degree rear uprights I bought (not the ones that came with the car) actually came in the hard material, although it doesn't say in the package.
You can tell by the greyish fibres strewn throughout the plastic (just look the chassis or the shock towers), unlike the solid black plastic of regular ones.
#1255
#1256
Anyone checked the price of a spare/replacement TA05 tub chassis ?
#1257
Originally Posted by cheehtae
I bought the rear uprights, both the 2- degrees and the 0- deg but both are hard ones, what I need to know is the part number for the Hard front c-hubs - 50985 is part # of reular plastic one, I need the the stiffer ones, anybody HELP.
Be careful about the caster. The old standard part of TA04 had more caster. As far as I know, we have 4 degree caster parts. If you see anything with less caster, let us know. I would like 2 - 3 degrees.
#1258
Alwin.
Alwin.
I found out that the speed controller I was going to use will not fit in speed controller bay. The bay is only big enough for speed controllers up to about 3 cm * 4 cm. My controller was closer to 4 cm * 4 cm. I intended to use old, moderate priced electronics, but I am ending up using my newest and best stuff on this car. It is turning out a strange mixture -- heavy steel dogbones on the back and upper price lightweight electronics. . . .
#1259
Did you brake it?
I saw spares offered on an internet shop in Switserland, I think (!?).
The price for the spare tub was 16,50 EUR. But I haven't seen them elswhere yet.
Alwin.
