Tamiya TA05 Touring Sedan
#1096
nanana.. I don't know what I'm replying about, delete...
#1097
Originally Posted by DA_cookie_monst
Will UK users be able to buy these items?? I am mostly interested in stiffening the stock chassis and don't want to go down the route of a new chassis/top deck/bulkheads/motor mount.
Steve Wang
#1098
Alum/TI turnbuckles
Hey guys,
I just got my 05 and have read through this whole thread as best I can. A few have spoke/shown blue alum or Ti turnbuckles on their cars. Who's are they and where did you get them? I have two Tamiya P/N's for the 3X32 and 3X23, but no one seems to have them... and Tamiya doesn't even have the 3X28's.... Any help? I thought I remember reading one gent used Associated rods? If so from which car? I'd really like to build this car right the first time.
Thanks in advance.
~Spazm
Thanks in advance.
~Spazm
#1099
Hy guys,
I'm wondering how you mounted the rear suspension front mount(aluminium). Did you have to file or something like that ?
tkx
tkx
#1101
Originally Posted by neosan
Hy guys,
tkx
tkx
I thought about ordering them to, so I hope they will fit.
#1102
Hy guys,
tkx
tkx
The widest rear front suspension block which will fit is a "B" BLOCK unless you go for the x series of blocks which are not as wide as the standard blocks. That way you don't need to file anything away.
#1103
Originally Posted by WarpdSpazm
Hey guys,
Thanks in advance.
~Spazm
Thanks in advance.
~Spazm
Have you tried RCMART they have a full range of Tamiya turnbuckles/tierods in blue and red and in 3x18, 3x23, 3x32 and 3x35.
You can alos try RC CHAMP who have a thread on this forum they could also order it for you if they don't have stock at the moment I bought a couple of TRF 415 turnbuckles(9805929) from them and they were very reasonably priced
#1104
Originally Posted by Skitee
Hi WarpSpazm
Well I'm putting together an order now based on your post. Does anyone know if the 32mm can be cut down to 28mm or will I have an issue with the threads not going far enough in on the rod?
#1105
I found that the 28mm shafts weren't needed because the 32mm shafts can be adjusted into the correct length, if you're thinking of going for the lightweight suspension set then your turnbuckle lengths increase anyway and you'll need the longer shafts.
#1106
So any updates if this car will be able to hold its own against the top cars. Just sold my A car and just need more convincing if I should get one with all the options.
#1108
Well,... maybe initially, but in the long run... Hell, the chassis is so cheap, I could afford to change a new chassis for each race !
#1109
Originally Posted by F1mechanic
Is the aluminum piece larger than the original from the kit? Which component do you want to fit in (tamiya nr.)?
Hi F1,
I was trying to mount the "D" blocks that comes in TRF415MS kit. As Skitee mentioned, we can use B blocks or go to X-series blocks...
btw, thanks a lot Skitee !!!!!
cheers
#1110
Narrow "X" series Suspension Blocks!
Hy guys,
tkx
tkx
Just flip the the block around for the bridge block for the front and add spacers!
