Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 08-30-2005, 11:56 PM
  #1081
ttso's Avatar
Hmm... I guess it would either be Square, Tech, or Kai...
ttso is offline
Old 08-31-2005, 12:07 AM
  #1082
JimmyMac's Avatar
I'm in...
JimmyMac is offline
Old 08-31-2005, 12:32 AM
  #1083
Ghostfit's Avatar
Originally Posted by Jam-ehz
Neato.. what kind of springs did you need on that track? Did you have to use the kit tires?
(On a side note, I see on the TA05 upgrade pamphlet a pic of grey springs.. do they make grey? I thought they went as far as white. Who would need them that stiff?)
I do !
Ghostfit is offline
Old 08-31-2005, 04:22 AM
  #1084
cheehtae's Avatar
Trader Rating: 15 (100%+)
My Ta05 will have a first taste of racing this coming weekend , Carpet racing, any suggested set-up?
cheehtae is offline
Old 08-31-2005, 05:32 AM
  #1085
Well, let us know how you get on, the only 'issue' I got with the TA05 at the moment for carpet is that the chassis has a little 'to much flex' which may make the car had to tune.
DA_cookie_monst is offline
Old 08-31-2005, 05:51 AM
  #1086
The TA05 is my first belt-driven car.
What tension should the belts be and how should I check this? When is it too loose or too tight?
Due to variable humidity the tension varies a bit.
F1mechanic is offline
Old 08-31-2005, 06:15 AM
  #1087
alana07's Avatar
Trader Rating: 53 (100%+)
Originally Posted by SpeedTech
Hi Guys,
Just want to post a quick news, for the new Tamiya TA05 sedan, we have a company that is working on a graphite upper and lower deck conversion kit together with aluminum front and rear bulkheads. No ETA just yet, but it is in the works and will be available in the US through Speed Tech R/C
I will keep you guys posted
Steve Wang
is that the TRF416???
alana07 is offline
Old 08-31-2005, 06:20 AM
  #1088
Jam-ehz's Avatar
Well, when I just run silver can and sport tuned motors, I can run it pretty loose, like being able to lightly press the belt down to barely touch the chassis parts below.
For 19T, I run it one notch tighter than when I could press it down that far.
I've only tried asphalt, so carpet may need to be even tighter because there's no give in the tires...
I'd probably try one notch tighter for mod, but that 19T tightness should be a good average to start with, especially with variable temps like that.
Also, I'm running the aramid belts, not sure if regular ones need different settings..
Jam-ehz is offline
Old 08-31-2005, 06:33 AM
  #1089
Thumbs up
Ok. I have aramid belts and after installating them according to the manual they felt tight. Now after they've been in open air the're loose.
I guess I will tighten them a bit as I am running on carpet next weekend.
Thanks very much.
Old 08-31-2005, 07:55 AM
  #1090
SpeedTech's Avatar
ttso,
Nice try We might have it under the Speed Tech R/C lable and if it can still remain cost effective, we might also include a titanium screw kit that will work with this new conversion kit.
Steve Wang
SpeedTech is offline
Old 08-31-2005, 07:57 AM
  #1091
Entropy's Avatar
Sounds more like Tech Racing or Kai Models doing their version of the TA05.
Entropy is offline
Old 08-31-2005, 08:07 AM
  #1092
SpeedTech's Avatar
Here are some soon to be in stock hop-ups for the TA05 from Square:
STA-6A Titanium suspension shaft (front outside)
STA-6B Titanium suspension shaft (Rear outside)
STA-6C Titanium suspension shaft (F/R inside)
STA-6F Titanium nitride coated suspension shaft (Front outside)
STA-6R Titanium nitride coated suspension shaft (Rear outside)
STA-7 aluminum servo mounts
STV-14F Front graphite body post support (same as EVO IV)
STA-14R TA05 rear graphite body post support
STA-34 aluminum battery hold down (can be used on EVO IV)
STA-35 Front steering knuckle
STA-36 Front C-hub
STA-38 Aluminum bulkhead (front or rear)
STA-50B Titanium universal bones
Look for these to be available here in the US 2nd-3rd week of Sept.
Steve Wang
Old 08-31-2005, 08:08 AM
  #1093
SpeedTech's Avatar
Few more pics
Steve Wang
Attached Thumbnails Tamiya TA05 Touring Sedan-sta34.gif   Tamiya TA05 Touring Sedan-sta35.gif   Tamiya TA05 Touring Sedan-sta36.gif   Tamiya TA05 Touring Sedan-sta38.gif
Old 08-31-2005, 08:29 AM
  #1094
Will UK users be able to buy these items?? I am mostly interested in stiffening the stock chassis and don't want to go down the route of a new chassis/top deck/bulkheads/motor mount.
Old 08-31-2005, 10:25 AM
  #1095
Ghostfit's Avatar
Nah ! .....you won't be able to compete in TAC or TCS with that chassis !
.....BUT ! for the other "Open" mod races ....
Ghostfit is offline
