Tamiya TA05 Touring Sedan
#7428
Trader Rating: 32 (100%+)
Originally Posted by Solara
I am planning to use 4.5 BL w/li-po on the TA05R...what would you guys recommand for the FDR..? 9-ish or 10-ish...? Thanks...
#7429
Originally Posted by Aluma
another question... are the front sway bar endlinks supposed to touch the universal? Should the links be straight up or leaned back? Usually the instructions say to move the ball end into the swaybar until about 2mm stick out. This manual says nothing. Same with the rear links... I set them vertical by moving the ball end out as far as possible without falling off the bar.
I ran outdoor....and I decided to not using sway bar at all.
#7432
Take off lane 4.....LMAO...clear for take off mr sLOw
#7434
Yes, back to the topic....I have try to mount the 105 stock spur with something like 22-23T pinion.....however, that aluminum upper brace on my TA05R does not allow me to move my 4.5 any closer to the spur....I think I can mount the 26/27T...thats it...
Don't made me use the dremel and hack off that aluninum center brace that can not be bought as a option parts from Tamiya....
#7435
#7436
RE: gear ratio!
Originally Posted by Nexus
If I can't get the ratio to run a Novak 4.5R system in this TA05R then there will be one partly built TA05R up for sale soon!!
I use the 109 with a 25 pinion, puts me at 9.8. The spur sticks at the bottom slightly but no interference. You can also use a 108 spur and that should work also to get you in the ratio you need, this doesn't stick out the bottom at all.
Just my2$
#7437
Originally Posted by maxepower
Use a 109 spur and then you can get in the gear ratio you'll need for a 4.5
Just my2$
Just my2$
What brand spur are you using..
#7438
RE: Spurs
They are white and very smooth. They also sell the pinion sizes you need, if you don't already have them!
#7439
Who wants that BLING BLING parts?
#7440
If that aluminum piece is the one that preventing us using 4.5 motor....I think we can use the stock plastic one.......and I heard ppl will pay top $$$ for that piece of BLING BLING cause it is not a option to buy, only on the TA05R car....
but if you're willing to sell yours. ill take it
