Tamiya TA05 Touring Sedan
#7096
Originally Posted by Core Creations
I haven't had a problem with electronics space and I run a standard size servo and a GTB speedo (which is huge)
On the anti-roll bar mounts...mine are a little loose, but I have always used lock collars like airplane guys use on their landing gear and use them to secure the bar...works awesome!
I agree the steering has a little play, but I had shims on my first 05 and just put new ones on my 05R, but without them it doesn't seem to affect the car.
I totally agree on the screws...they should have included steel hex screws.
I agree that the steering rack is sloppy. I was thinking about getting the CF link because the bearings might tighten it up a bit. Anyone have this part? Does it help?
#7097
I would think as long as it doesn't enhance the cars performance they probably won't care.
The carbon link desn't do anything for the slop...the slop is in between the front brace and the bearings in the steering. The posts that the bearings slide on to are about .5mm longer than needed and you just need to shim that out.
#7098
Originally Posted by bigb11
is there a release date, picture anything????????????
I was planning to get a TA05R and now I should wait!
#7099
Originally Posted by trf_racer
It will be showcase in the Shizuoka (spelling?) Hobby show in Japan
When is that?
#7101
Regional Moderator
I'm surprised that the issue of electronics space pops up now and then.
I managed to fit...
-My KO 2173 in with only removing the needed ear. I didn't have to remove anything on the other ear or file the chassis. And if you use the kimbrough med servo saver(without predrilled holes) then you wont have to do anything with the servo saver or chassis at all.
-My Novak Xxtra is HUGE. Easily one of the biggest FM receivers on the market. It fit flush into the chassis with room to spare behind the servo, and room to spare side to side. I can't imagine how big a receiver would have to be not to fit.
-As for speed control space, I always figured that if the GTB and LRP Spere could fit in there with no problems, that just about anything could. I knew the Tekin G10/11 wouldn't, but a Keyence...wow.
I managed to fit...
#7102
#7104
Originally Posted by Solara
No matter how many times I look at this pic....the car looks SHORT, wheels are way BIG, and looks like a 1/12th TC for me....or isn't it? (I know that is the 25th year 911 special TA05...and HOPE that is the MS version cause that is what I don't need....)
That Special Edition inparticular is 'short'.. To fit the proprtion of the Special Edition Body..
My guess is that the TA05MS will be similar to this... but not 'short'..
#7105
Here's some update for the TA05MS, it is translated from Japanese.
TA05 and TRF415 it sets motor helicopter loading site to center almost, adopting the upper 2mm thick, [rowa] 2.5mm thick carbon double deck. Looking back characteristic and the good quality of the throttle response of TRF415 where TA05 is superior it was compatible at high dimension. Furthermore the front and back wide pitch pulley, equipping front one way and the aluminum motor mount etc of cantilever center shaft specification, this chassis kit was finished in the TA05 series strongest machine. Residence player complete supervision before ●TRF - As for center pulley direct type - As for damper stay also front and back 3mm thick carbon make - Front and back common high accuracy aluminum make bulkhead - Equipping the aluminum make steering wheel arm
#7106
That'll cost as much as a 415msxx!!!
#7107
#7108
Originally Posted by Hebiki
boy you sure do know how to tease the TA05 fans on this thread!
#7109
Originally Posted by daveaustin5
So the same as TA05R except: carbon twin deck chassis and shock towers, aluminum bulkheads and motor mount and a front one way.
Steering (most likely the EVO5 type), Motor Mount (Porsche 934 Type), Damper Stay, etc.....
I hope the upper deck is lower than the Porsche 934 as that one is quite high (higher than TRF415MSX)
#7110
