Tamiya TA05 Touring Sedan
#4096
i cant wait see the pictures charile b
#4097
I'm gonna pick up one of the Ferrari based kits. I've put it off because I just spent a bunch of money on a used TA04. Well, what is left of it anyway. The front and rear are about all that is left of the original.
#4098
Will do. our next TCSrace is next month around the 18th or so. I will try the set up and respond back.
Originally Posted by Masa
New Flap TA05 Conversion!
http://www.rctech.net/forum/showthread.php?t=54798
#4099
Regional Moderator
Installed my center one-way today. Anyone else notice that the fit seems a little tight once its installed? To the point where it causes the pads to squeeze the one-way pulley and take away some of its freedom.
The instructions say to install a .3 and .2 shim. I found that removing the .2 shim was neccesary to get the one-way pulley to spin as freely as I thought it should.
Anyone else run into this?
#4100
Originally Posted by BrainTeased
yea the evo 3 share the same suspension as ta-04 and ta 05 as well as tb-02.
I'll try to order it, then...
#4103
Originally Posted by akuhon
Hi all,
I am thinking of upgrading my TA05 rear uprights with the alum ones..
I notice there are 3 kinds of alum rear upright made by Tamiya AFAIK,
53687 TB Evo3 Alum Rear Upright 1 deg
53784 Evo IV Alum Rear Upright - 1degree
53804 Evo IV Alu rear Upright - 0deg
Which one still use 1150 bearings ?
I still use std suspension arm and want to use the same size 1150 bearing.
Thanks for the help ..
#4104
looks a beast charile b wots the price going to be on them
#4107
You'll take out atleast 40 grams in that mod. Try using a S9550 servo aswell and also have Titanium driveaxles allround will take another 10 grams and also using a personal transponder helps.
#4108
Guys,
Did anyone of you seen this??? http://www.tamiyausa.com/articles/ln...hi%20setup.pdf
Do you notice that he is using the option suspension block? He is using 1B & 1XC for front and 1XD & 1B for the rear.
The thing is, I can only find 1A,1B,1C,1D,1E or X, XA, XB, XC, XD but I cant find those 1XA, 1XB,1XC, 1XD... I am confused..
BTW, My TA05 is almost done. I had the Front oneway, CF shock Tower, LW lower deck, TRF dampers, Alum. servo mount, UJ and Stabilizer bar. I still need to get the suspension block and hard arms.
#4109
i just got myself some universals. the 46mm type. should i get the longer shafts 48mm for the front at least or will i be fine with the 46mm shafts??
