YOKOMO Touring Car BD-7
#5266
Hi Guys, on my BD7 2015 the front stearing end bell seems to have a little play in it, it almost "tweaks" when the servo turns full lock left and right. It sort of rocks rocks, I've tried shims etc to try hold it in place more but it still rocks slightly. I end up with almost a degree of toe in our out based on this play when the car is sitting on my setup station. Is this an issue of over tightening or has someone else experienced the same?
#5268
My setup it not far off from yours, but mine is the 2013 version. If I remember right, you had the 2013, right? Any difference in setup and handling between the two?
#5269
Sorex 28's for the win! What insert are you running? The hot ticket in Japan is Sorex 28's with Sweep light weight blue inserts.
14' has more steering, and at the same time, easier to drive
#5271
Yes, but only for asphalt. I used 2.5 million GRC up front and worked like a treat. Under hard acceleration the rear end stayed planted and the car was controllable coming out of the corners, whereas the spool would cause the rear to break loose. Please note that this was on a tight technical race course. I've never tried it on carpet and probably stick with using a spool.
#5273
#5274
http://www.petitrc.com/reglages/yoko...vas2013080104/
Kyosho 2K in the gear differential.
1 mm on the bellcrank
0.5 mm shim underneath the front and rear inner link.
5.0 mm front and rear hexes.
That's it really.
Is it me or did I once see a picture of Roland V's BD7 2013 motor mount with a grub screw in place?
That's it really.
#5275
That's it really.
That's it really.
Found it!
#5276
And your answer was the first thing mentioned in someone else's post and Lonestar commented there was more to the geometry which it isn't.
Read all the relevant posts if you want to save your embarrasment.
#5277
I know some people feel they are empowered on the internet. But I've noticed you generally are a smart ass on every chat room. And feel you have to put your opinion on everyone's questions. Just the other day I seen your post when someone asked in one of those "what car to buy threads". Your first words were basically calling him a dumb ass for asking. I can beat you with nearly any chassis from 2002 on. If you think you have to be an ass. Just don't respind to people's "stupid" questions.
I know what I answered and am responsible for that, not for what you or anyone else makes of it.
What about chassies prior to 2002?
Oh, and by the way, it's spelt "respond".
#5278
Niznai - you would fit in at performanceforums.com really well.
You could use the language you're really thinking but refraining from typing as well.
#5279
Could anybody tell me when and where could purchase this aluminium chassis?
http://www.redrc.net/2014/12/ex-lab-...is/#more-90752
Best regards
Best regards
#5280
