YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 03-11-2014, 04:21 PM
  #3766
If grip is really low, it might actually be worth trying less camber.
-Mike
grippgoat is offline
Old 03-11-2014, 05:26 PM
  #3767
EDWARD2003's Avatar
I looked at your setup in RC CREW CHIEF. It's show's your setup is pushing bad from mid to exit corner.
A: I would look at increasing the camber gain for both front and rear.
1- Take out the 1 mm spacer out from the front inner link. You need more roll on the front
2- Raise the rear and upper suspension blocks by 0.5 mm. This will increase the camber gain both front and rear, if traction is low than more camber gain will help. The front will have 0.23 degree of camber gain and the rear will have 0.12 degrees. Originally, your camber gain settings were 0.8 F and 0.7 R.
B: Increase the rear camber by -2.0, the front looks good.
C:Run HPI Silver front and rear. Right now, your front ride stiffness is greater than the rear. I would suggest taking the front shock down to the same hole position as the rear and highly suggest changing the spring to HPI silver.
D: Lower your ride height a little bit, if you can 5.5 front and rear.
E: Add 20 grams of weight up at the front.
EDWARD2003 is offline
Old 03-11-2014, 10:41 PM
  #3768
Racing4Evo's Avatar
Default Setup for Sweeps on Medium Grip Carpet
Here is my current setup on Sweep tires also purchased on 3/7/14 from TQRC Raceway and used that same day. The batch of Sweep tires I used have the translucent white "natural stiff" wheels, I'm not sure if the rubber has changed since I don't use Sweeps too often. This setup is a work in progress and will get much better but it is still very easy to drive.
I want to stress that I am using a Tamiya servo saver, which is equivalent to using the short kit servo horn. A shorter horn makes a big difference in calming the steering down.
Racing4Evo is offline
Old 03-12-2014, 12:45 AM
  #3769
JimmyMac's Avatar
Thanks for the setup. I see that you goop your rear tires a lot longer. Are you doing full front sauce and are your front sideways superglued? That was the only way I have been able to calm those tires down.
JimmyMac is offline
Old 03-12-2014, 01:19 AM
  #3770
Originally Posted by CristianTabush
Lastly, tire treatment. What are you using as an additive?
I didn't use additive yesterday, the track was to dirty.
Just heated to 50°C 10 minutes before.
Thanks for so much tips. I noticed all and will try it in the next days.
walzjer is offline
Old 03-12-2014, 01:51 AM
  #3771
Have u guys tried to place both spool and diff in high position?
I find it gives the car at bit more roll in the corners, anyone who can confim this?
RCmcDriver is offline
Old 03-12-2014, 03:59 AM
  #3772
The Teacher's Avatar
Trader Rating: 62 (100%+)
Had my first practice day on my new BD7 2014 yesterday and I must say the car is very nice... I do however need to find 4 deg caster blocks as my track is a very high grip tight carpet track...with unforgiving boards. Do any of you guys know of anywhere that has them in stock(and ship to US)???
The Teacher is offline
Old 03-12-2014, 04:21 AM
  #3773
Jorge T's Avatar
Trader Rating: 14 (100%+)
only amain hobbies has them in the US, unless someone else "grey markets" them
Jorge T is offline
Old 03-12-2014, 05:40 AM
  #3774
cyba888's Avatar
anyone tried running a front diff with 2.5 million cst?
cyba888 is offline
Old 03-12-2014, 06:53 AM
  #3775
JimmyMac's Avatar
I have. In most cases it makes the car easier to drive for me. It kind of smooths out the steering and makes it more constant. I also don't run them with blades. I use the steel outdrives. I just switched back to the spool for now. Can't decide which I like better.
JimmyMac is offline
Old 03-12-2014, 07:00 AM
  #3776
JimmyMac's Avatar
Have you tried Banzai, ApexRC, ToniSport, or RCMart? I currently run the aluminum Arena ones from Rcmarket. But I do have regular plastic backups.
JimmyMac is offline
Old 03-12-2014, 09:26 AM
  #3777
cyba888's Avatar
Was this on asphalt?
cyba888 is offline
Old 03-12-2014, 12:52 PM
  #3778
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
ApexRC has them in stock, and have US Distribution
http://www.apexrcproshop.com/index.p...d=93&limit=100
RedBullFiXX is offline
Old 03-12-2014, 01:32 PM
  #3779
JimmyMac's Avatar
Nope sorry. We haven't started racing outside yet. I'm going to start with a spool outdoors. If it's a small tight and technical track, then I'll try out my diff.
I wouldn't mind trying some of the Reflex stuff in my diff.
JimmyMac is offline
Old 03-12-2014, 04:54 PM
  #3780
EDWARD2003's Avatar
I prefer running Gravity RC 2.5 million cst over the spool on my tight twist asphalt track. I found the spool would launch the car hard out of the corners and cause the rear end to lose traction. After switching over to the 2.5 million, the car settled down and became consistent and easier to drive. Highly suggest it for outdoors.
