YOKOMO Touring Car BD-7
#3781
Here is my TQ/win setup from the ACT titles last weekend. Things I found most effective in low grip were to stand the rear shocks up to hole 3 and raise the rear blocks 0.5mm. Also agree with the comments re: bump steer - too much definitely makes the car loose on power.
I found the front diff easier to drive and it turned in a little better, but I if I wasn't TQ I would have run the spool to make passing easier. Any questions feel free to ask
#3782
#3785
shimming RF blocks = will give you anti-squat less weight transfer to rear of the car.
Shimming RR blocks = will give you pro squat more weight transfer to the rear of the car..
#3786
Shimming both RF and RR suspension block with the same amount of shims will lower the roll center increasing rear grip..
RF and RR block = bulk head cap?? Thanks
#3788
-Mike
#3791
#3792
Good morning from Germany!
Yesterday I tried a few things. The setup is attached.
Car feels much better but its too slow. It feels like in corners with more speed theres to less steering and in slower corners the rear is loose.
I will try raising the rear suspension mounts. Didn't had the time for it yesterday.
Also the things for 2 orings in the shocks arrived yesterday and I will build that today.
#3793
#3794
What is the purpose of running negative expo on the steering?
