YOKOMO Touring Car BD-7
#4531
There is a plastic battery stop option that weighs about 1.5g w/ Ti screws. With the board barriers we use in the US, I just don't trust not having something in place.
#4532
Your next hopup/purchase should be a lower mAh battery pack in the 300g weight range. Getting that weight down will greatly improve handling and power. Based on the info that you've posted, it's possible that you may be 50 -70g over weight.
Oh yea, forgot to mention that I am running my car in 17.5 blinky and converting it over to USGT class. I haven't figured out how to do so to get my weight down for 17.5 but I meet the weight for usgt
#4533
For balance the best weight battery I have found is 295g it is still a touch battery side heavy so I placed the ESC a few mm further out.
I would guess the perfect weight battery would be 285g.
Using HW ESC, futaba servo and Orca Tx 13.5T motor.
#4535
Does the spur gear adaptor and pulleys from the '14 fit the 2013 BD7?
I tore my rear pulley straight off the spur holder LOL. Don't know how it happened, anyone else managed to do this?
Thanks.
Thanks.
#4536
I place 20g (10g + 10g) under the receiver. This balances out my BD7 with a 6000 pack and 17.5 and fan.
#4537
[/QUOTE]
There is a plastic battery stop option that weighs about 1.5g w/ Ti screws. With the board barriers we use in the US, I just don't trust not having something in place.[/QUOTE]
Light weight battery stop info:
http://www.rctech.net/forum/australi...2013-14-a.html
#4538
#4539
Actually, there is a big difference in weight between an ORCA motor and say a Reedy motor. I think it was around a 20 gram difference last time I weighed them.
#4540
I don't have a reedy but the difference was about 5-9g to my other motors. Which rotor was in the reedy?
#4543
I measured 13.5T killshot (rpm), 160g so not much in it.
From post on here the D4 is 170g which is not exactly light.
Reedy appears to be pretty heavy in comparison.
#4545
changing it up
Hi race fans.
Been seriously considering changing to a BD7 from my t4'14.
I run low grip outdoors and have really been struggling to find the sweet spot for the xray at my home track.
Really after peoples thoughts thst may have ran both.
Im currently running 13.5 boosted for what its worth.
Look forward to your input
Cheers
Mick
Cheers
Mick
