YOKOMO Touring Car BD-7
#3181
Conversely, A friend of mine puts some whitening tooth paste inside and chucks it up on a drill to break the gears in, which helps them break in and become smooth. My only concern with that is the oring possibly getting fouled up.
On the Kyosho O Rings, they are not quite the exact same size and from experience make the diff not be as free. Personally, I run the stock O rings with Zero leakage. The only thing special I do is put a couple of drops of oil on the o rings and also soak the paper gasket with oil. I then crank it as hard as I can without using excessive force so as not to strip it. The diff comes out much freer this way.
If i would run the Kyosho o-rings, I would probably run slightly softer oil.
#3183
good rubber asphalt additiveĦĦĦĦ
sorry
#3185
Last night I changed the diff fluid on mine and found that one side (pulley side) was tighter than the other. I sanded the sun gear like Cristian mentions and it freed up.
I also have a leak free diff with OEM O-rings. When new I dissembled it and put some black grease on the axles before filling it up with oil.
#3187
With my diff the outdrive at the pulley side was also tighter then the other side, sanding the gear wouldn't help because is already noticeable whit only the shim and the pin.
I guess this caused to make my car feel tweaked while i couldn't find a reason.
My diff leaked very bad whit the oem o-rings so i had to use the kyosho's, i tried to use some yokomo protection grease at the o-rings but it didn't help.
#3188
Trader Rating: 51 (100%+)
Hey Guys, found this might be helpful to some hope this helps
http://www.youtube.com/watch?v=m_DhcfcO8dI
#3189
Yokomo's BD7 2014 video with interviews of Ronald Volker
https://www.youtube.com/watch?v=_ydLfk53ar8#t=38
#3190
Probably worth watching if you speak Japanese lol.
#3192
Just curious, but do any of you guys run the Yokomo battery pad on the chassis?
#3193
Hi guys!
I am thinking about buying new BD7 2014. Can you tell me which option parts should I buy? Are you all using Yokomo ECS or is there any other option?
I am also not sure about the springs. Should I watch for "long type" springs?
Thank you in advance for your answers!
#3194
Hi guys!
Still trying to work out the best way of running DCJ's. The Yokomo item is notoriously fragile. A lot of people use the Spec-R which is surprisingly durable, but the drive pin is actually too small for the BD7 outdrive.
Some people use Tamiya ones, and there is a Roche option too.
