Hot Bodies Cyclone
#1216
ngo8- it does not say on his set-up sheets
#1217
Just wondering if anyone has dared to drill some holes in their chassis to mount holders for a battery bar instead of using tape? I know tape is better for balance etc. but I've never used it before and was wondering if anyone has modified their car to use a battery bar?
#1218
#1219
Yea, I'm just a bit worried about drilling into a brand new chassis :S I've bought some tape anyway so I think I'll see how it goes for a while...
#1220
I'am also thinking about mounting a batt bar i don't now if i am giong to use the one from hpi because it isn't that pritty the one from the FK 05' of yok bd is nicer but from the 05 it's expensive so i don't now i am still al little worried to drill holes in the new chassis but with my expertise it's going to be okay.
greetings hollowman
greetings hollowman
#1221
#1222
oh yea forgot to ask what benefits do you get from a bigger spurgear do you need it for even a tighter carpet track?
#1223
Originally Posted by axel
have you ran it yet?
We got some of the ball diff pullies in stock yesterday...I quickly built a front diff with the pro4 parts to confirm that it would fit correctly like the spool does. Using the CVD's from the pro4 also and a bunch of shims to center it(something like 3.1mm on one side and 3.3mm on the other), it fits just fine!
This will be a good temporary solution if we can't get spare diffs soon enough . You must use the ball diff pulley, though; the one-way pullies have been reamed out to fit over the one-way.
#1224
what does the cyclone come with is it dual diff ?
#1225
Cyclone Rubber/Carpet Setup
Does anyone know hara's setup that was used in vegas or any set for the cyclone for rubber tire on carpet. Thanks
#1226
#1229
HI,
someone knows how many spacers put under the pivot block in order to have 0 Deg Anti-dive and 0Deg Anti-squat?
Whit the standard set-up there is some anti-squat and anti-dive(but the manual don't show how).
Also someone knows what uses Hara?
