Hot Bodies Cyclone
#1966
Originally Posted by ngo8
ooookay here it is
#1967
yeah just got those packs very happy with them 1.206 @420sec sweet ass
#1968
Originally Posted by nordheim
I mentioned it first on page 40. You can see all the replies from that point out. It was Rc-Zombies who first posted the trick with the 2 bearings instead of using the 2 plastic spacers. I scratched my head so much as a result of how sloppy the diff was but I guess sloppy is good
#1969
ok here is a little feedback on the drivetrain being to tight as i was loosening the screws to take out the diff i tryed rolling the car and it was so much more free there was no resistance or anything the car rolled pretty good so when you go to tighten the bulkhead do not overtighten the screws as it binds the bearings and they make the car very tight .
Also, when you put the bulkhead bridges on, dont do it while they are connected to the shock tower, this can cause the bridges to be at an strange angle, so when you tighten them down it pinched the drivetrain and makes the car unfree.
Individual bridges on first, then shock tower once they are secured.
Stew
#1970
hara set up at the roar nats he gave me
caster angle 1.5
castor 4
ride height 4.5
droop 6
oneway
stablizer bar is 1.4
toe angle 0
f2mm r2mm under front diff pivot block front/rear
underbulk head 2.5 in the#1 postion
2.5 block in front
shock piston 1.2 #2hole 40wt front 30wt rear
springs front hpi white/rear hpi silver
bladder standard
frontshock tower #2 hole on a arm#1hole
front sway bar 0mm spacing
now for the rear
#2postion on rear tower
#1 on rearhub postion
.5 under bulkhead #1 position
1.5front/1.5 under rear under diff
#2 on a arm
3.0 block on rear
1.5 camber
ride height 5mm
droop6.5 mm
1.2 stablizer
ackerman 4mm
spur 107/30 7 turn
#2 position on front hub
if i missed any thing that what hara gve me at the nats
castor 4
ride height 4.5
droop 6
oneway
toe angle 0
2.5 block in front
bladder standard
now for the rear
#2 on a arm
3.0 block on rear
1.5 camber
ride height 5mm
droop6.5 mm
1.2 stablizer
ackerman 4mm
spur 107/30 7 turn
#1972
post #1590, I asked for help with the diff. It's towards the bottom of page 40.
#1978
regarding the Shooters bulkheads...
i installed mine this weekend and they fit perfectly.
Originally Posted by HKRCMODEL
I'm B4 was said that not 100% fit
#1979
Where did you ordered them from?
#1980
