Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 04-08-2008, 01:07 PM
  #11731
RCFREAK's Avatar
Trader Rating: 20 (100%+)
run 1/2 degree block in right rear and 0 degree left rear.. just kiddin now i gotta check mine..
RCFREAK is offline
Old 04-08-2008, 05:20 PM
  #11732
NickM's Avatar
I run 81t, 48 pitch spurs on both by WCE cyclones with no problems. Ample clearance, and it's flush with the bottom of the chassis. Mangoman does too. We run the thin white spurs, RW brand maybe?
NickM is offline
Old 04-08-2008, 10:40 PM
  #11733
Trader Rating: 23 (100%+)
OK boys....I'm looking for a hot setup for rubber tire on carpet. This is new for me, I've never run rubber on a Cyclone (don't laugh). I might run a little asphalt this summer too although it'll be a shame to scratch up a chassis. Any help with setup would be appreciated!
pcar951 is offline
Old 04-08-2008, 11:36 PM
  #11734
SammyZ's Avatar
Trader Rating: 138 (100%+)
just put a chassis protector on it, thats what Im gonna do. You can get them anywhere, hot bodies even has their own.
SammyZ is offline
Old 04-09-2008, 12:43 AM
  #11735
Lonestar's Avatar
Trader Rating: 14 (100%+)
This is sooooooooo weird... I tried an 81 spur no later than saturday (raceday) and it did stick below the chassis like crazy on my Hara Ed... I'm wondering whether the WCE wouldn't already have modified motor mounts...
tonite is practice time - will check again.
thanks all for the help!
Paul
Lonestar is offline
Old 04-09-2008, 12:48 AM
  #11736
Lonestar's Avatar
A fantastic spool mod setup with grippy tires is Andy Moore's DHI winning setup, it worked beautifully on raceday saturday - remove the rollbars if grip isn't that fantastic as they do tend to make the car slide around a bit (still in a balanced manner though). I can't attach it as the pdf is too big but look it up on the web and it should be easy to find.
"base" setup for one-way grippy rubbers on carpet is the super-famous "1.5" setup - rolle centers raised 1.5mm via shims under all pivot blocks and ball joint holders on chassis side, 4mm ackerman, LWB all over, 40 to 50 oil all around with 3-holes 1.1mm pistons, pink springs front blue springs rear, 6mm droop front 5mm droop rear, that's with a mazda 6.
Laters
PAul
Lonestar is offline
Old 04-09-2008, 01:22 AM
  #11737
mangoman's Avatar
Yeah a lot of places have 81T listed as the largest spur you should run. People have run a slightly larger spur so that it pokes out slightly under the chassis (ive tried an 82 and that works fine).
I think they are RW Racing supalite spurs. However as they are thin and only screw in with only two holes so i find they tend to warp easily. You should probably use the CF spur gear plate to attach them but im a lazy old fart.
Ive got a xenon spur gear in at the moment which are meant to be the good stuff (i believe all the Team HB drivers use them, but 64 pitch of course). The spur is incredibily durable however my car is really noisy and im pretty sure its because the spur doesnt like the pinions which i use.
mangoman is offline
Old 04-09-2008, 03:36 AM
  #11738
Originally Posted by Woz
i bought my cyclone wce about 6months ago (Normal colour carbon chassis) and everything is equal. I would ask to have the chassis checked. Have you used a proper setup station to check the rear toe (i.e. a hudy setup station) i would make sure everything is correct on the build.
I have measured in a hudy setup station all the time. I'm really very disapointed and don't know what to do now. One race passed now and nothing to do, but at least i wish to save the rest of the championship. Does anyone know someone at HPI/HOTBODIES Europe?
jorgesimes is offline
Old 04-09-2008, 03:56 AM
  #11739
komkit's Avatar
Not sure if this had been suggested.
Since the Cyclone upright and the suspension arm can be used on the left and right. Have you tried to switch side and see if the problem follow?
Try one thing at the time. Hinge pin, Arm and the upright. Make sure the hinge pin isn’t bent, suspension arm stay flat on the flat surface. Also pivot block should stay flat on the flat surface as well.
komkit is offline
Old 04-09-2008, 05:29 AM
  #11740
Lonestar's Avatar
Mmmh. that rear asymetry thing reminds me of the good ole' TC3 days where Cliff himself was swearing to anyone who could hear him that the rear end had perfect 3deg toe in on each wheel and that one should be careful when tightening the rear blocks... Sorry, can't help you on that one jorge, good luck
Regarding that spur issue of mine... thank you guys for convincing me to revisit my setup. the 81T spur fits fine with a 21 pinion, which gives a 9.4 ratio perfectly acceptable for BL 4.5. For some reason and in the stress of a race last saturday, I didn't get it to fit but it does today... the bearings were probably aschew or something. And by the way it's not the bearing "rib" that prevents the motor from backing to the max of the holding screw oval holes, but the cage itself that hits the bulkhead on the side... My fault all along!
Thanks again fellas
Regards,
Paul from Switzerland
Lonestar is offline
Old 04-09-2008, 06:19 AM
  #11741
I was at the same race with jorge, and i've tried everything i could remember: i switched hubs and arms and tried diferent arms and hubs. I did manage to improve my rear toe-in from 3º/1.5º to 3º/2º, but the problem remains.
We both had problems when turning left, and we both had the least toe-in on the right wheel, so it cant be a coincidence.
BTW i measured the toe-in right after assembly so im sure is not a damaged part or anything like that.
Itchy is offline
Old 04-09-2008, 06:43 AM
  #11742
komkit's Avatar
Ummmm...
When you moved the suspension components from the left to right and right to left, did the measurement changed to 1.5º/3º to 2º/3º instead of 3º/1.5º to 3º/2º?
komkit is offline
Old 04-09-2008, 07:15 AM
  #11743
No, it remains the same. Left 3º - Right 1º
We even try changing parts from itchy car into mine and the problem remains.
When i changed the rear to 2,5º blocks it gives. Left 2,5º - Right 1º.
Old 04-09-2008, 07:26 AM
  #11744
Im not sure i understand your question, but what i did was: swaped hubs and checked toe; swaped arms, then checked toe. Than i tried different hubs and arms and checked toe after the assemby. When a particular piece improved the toe diference i would let it stay.
If i remember correctly, it improved when i swaped the hubs. The swaped arms didn't make a diference. New arm made litle diference too. It was borrowed, so i let the original stay.
Itchy is offline
Old 04-09-2008, 07:57 AM
  #11745
SammyZ's Avatar
thats funny, i just checked mine again with 3 degree rear block, the left side measured 3 and the right side measured 1.5. I will check the holes in the chassis to see if they are aligned properly, i am assuming there not.
SammyZ is offline
