Hot Bodies Cyclone
#9556
Cheers Malc TCCFM
#9557
#9558
Never mind lol..... Dad just bought me a Orion 10.5 Vortex
My set up is
1.5 deg on camber front and rear
3.0 pivot block in the rear, 0 in the front
40wt shock oil
Hara's grey soft shock spring kit
silver sway bar up front, copper in the back
0 toe in the front
4 degree c hubs
front shock are in the 3rd hole being stood up
Rear shocks are in the 5th hole from being stood up
4mm of ackerman
Front spool
Locked center pulley's
No shims under my toe blocks
Anything else needed to know?
My set up is
40wt shock oil
0 toe in the front
4 degree c hubs
4mm of ackerman
Front spool
#9559
Steering servo's
Guy's
Whats a good high speed steering servo and do we really need a high torque servo for 1/10 touring.I also heard that the Hitec servos dont centre very well is this true??? Thanks
Taffyjnr5
Cyclone (Black)
Novak 13.5
Spektrum
Taffyjnr5
Cyclone (Black)
Novak 13.5
Spektrum
#9560
is the 55400 cyclone kit worth getting if you can get it for about half the cost
of a wc kit ?
of a wc kit ?
#9561
#9562
Cyclone S issues
Hello all,
I have a few questions regarding part numbers and upgrades for the Cyclone S. I recently bought a used Cyclone S for my son and I did a once over on the car and found numerous installation errors. After just 1 and a half runs the front diff outdrive (right side) broke and the rear diff became super loose. I took apart the rear diff and it appears the prior owner broke the left side of the diff outdrive and used super glue to mend it back together Now I have to repair two diffs which will cost me as much as the whole car. I am looking to upgrade them to prevent the same thing from happening. I would like to get the universal driveshaft and wheel axle for the front and use the aluminum diff outdrives with the retainer.
Part Number for the universal driveshaft with the wheel axle?
Will the aluminum outdrives used on the higher end cars work on the "S"?
I plan on replacing the bushings in the diff with bearings and using the carbide diff balls since I have rebuild the whole thing anyways.
Is this car worth all this extra money or should I cut my losses and look for a used Cyclone black? Thanks for any advice and tips you can give me.
#9563
Try this link dude
http://search.stores.ebay.co.uk/Dinb...095710QQsofpZ0
Hello all,
#9564
The KO has more torque then the Futaba s9550, so I like my s9550! Good servo
#9565
Servo's
Hi,
Just bought a Futaba 9550. Thanks guys
Taffyjnr5
Cyclone
Novak 13.5
Spektrum
Taffyjnr5
Cyclone
Novak 13.5
Spektrum
#9566
#9567
#9568
Does any one know the part number for the Hara One-Way V2 OutDrives? I don't see a part number in the supplement manual for just the out drives. Thanks.
Snowy.
Snowy.
