Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-09-2007, 08:29 PM
  #9406
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by nc racer
well, i hooked up my mamba 7700 in my cyclone today and i'm not too impressed. too twitchy steering and some kind of torque steer ( like in a shaft drive) and absolutely zero brakesn it just spins around. i'm sure i've just got some setup issues to work out. but i cant figure out why i would have shaft like torque steer? anyone have any ideas or any recommendations on a high speed brushless setup for asphalt?
Well whats your set up?
I throw my mm 5700 in for at home fun, and my car is just as hooked up as it is at the track... So something is set up wrong
BlackedOutREVO is offline
Old 08-09-2007, 09:17 PM
  #9407
its pretty much set up by the book from what i can tell. i bought it used from dodgeguy on this forum. the only thing i have changed is to get the brushless motor mount and gear it 110/25. running swaybars on front and back. silver springs in back and gold up front . dont really know what info you need.
any help is appreciated and im sorry to bug you guys with all the newbie questions.
nc racer is offline
Old 08-09-2007, 11:00 PM
  #9408
kschu's Avatar
Trader Rating: 16 (100%+)
hi, i'm new to cyclone
i bought a used cyclone chassis. i got a question.. if i chg to 3racing 1 way centre pulley. if i use 18t, i need to chg d rear belt ?? will it very tight if i din do so ???
i running stock motor 23t.
thanks in advance....
kschu is offline
Old 08-10-2007, 01:20 AM
  #9409
rbalint's Avatar
This pulley was on Ronald Völker's car, he told me they are 20T pulley's.
rbalint is offline
Old 08-10-2007, 08:01 AM
  #9410
barber's Avatar
i run a 7700 brushless setup with no problems at all it is the hara cyclone ,i run it at club racing you probably need to setup the profile on the computer and then load it to the esc then work on your suspension set up also you would need some good tyres.
you can go on hot bodies web site and compare setups with the pros.
barber is offline
Old 08-11-2007, 04:58 PM
  #9411
Originally Posted by rc-zombies
That's what I thought too... and was thinking it might be 19T to get a 2.052 transmission ratio.
For those that PM'd me...
2.0 transmission: 36/18
the belts are very very loose at the moment... looking for front/rear belts that are 1 tooth less than stock.
for now this is what I'm using:
(2) sets of 3Racing red belt tension cams
(2) sets of 3Racing 18T pulleys
(1) rear belt tensioner
(2) Pro3 36T diff pulleys... one of them you'll need to ream out to fit the one-way or spool.
able to get to a 4.6fdr using a 106/46 5cell for 10.5bl.
2.1666 transmission: 39/18
(1) Yok BD rear belt 189mm 63T
(1) Mi3 front belt 510mm 171T
the yok rear belt is a perfect fit.. waiting on the Mi3 belt to arrive. and I'll confirm fit. with the stock front belt..it's way way too Tight!! don't try it!
if you do order the 18T 3racing pulleys..make sure you also order some replacement pulleys... they are made for the TAO5..but fit the cyclone mounts and come 2ea.. 16/17/18T
pics of the 18T pulley installed and 3Racing 5cell chassis.
Ramon, If I asked you would you solder black wire's onto my sphere tc? I can solder, But its more on and off with the wire right into the speedo lol And frying a 200 doller speedo would SUCK....Its a fast task isnt it?
And 2nd, Well for anyone, If the sphere tc is sitting so the wires (motor and batt wires) are facing the batery, how far does it hang off the chassis?
Old 08-11-2007, 05:52 PM
  #9412
Vicko's Avatar
Trader Rating: 14 (100%+)
hey did anyone post an set up for the cyclone, for high bit, smooth
asphat? and who makes the 18t center pully.
Vicko is offline
Old 08-11-2007, 05:59 PM
  #9413
Guo Chean's Avatar
3 racing make those pulley
Guo Chean is offline
Old 08-11-2007, 06:14 PM
  #9414
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Damn Guo I thought I was on all the threads!!!!!!!!!!!!!
wyd is offline
Old 08-11-2007, 06:45 PM
  #9415
Guo Chean's Avatar
you are different Lol how was your new car handle?
Old 08-11-2007, 09:56 PM
  #9416
rc-zombies's Avatar
just received the Mi3 belts..it's a little wider than stock.. 3.5mm vs 3.0mm width.. and it fits perfectly.
rc-zombies is offline
Old 08-11-2007, 10:18 PM
  #9417
Old 08-12-2007, 12:00 AM
  #9418
i just got a hb i am runing stock and 19t i have a 108 sp what pinion should i run? and i cant find the moore speed shells any one know the part #
team-srh1 is offline
Old 08-12-2007, 05:22 PM
  #9419
Vicko's Avatar
hey who makes the hard front bumper for the cyclone and anyone know
where I can find one?
Vicko is offline
Old 08-12-2007, 05:25 PM
  #9420
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
try here the pro4 bumper is the same!!
http://www.racing-cars.com/usa/searc...rtname2=partno
Marcos.J is offline
