Hot Bodies Cyclone
Super Moderator
Yes, the Core R/C pack will also fit.
foam carpet help
Hi Guys I've been running the cyclone for a year now and have really struggled with a set up. I've tried a few and have made my own changes with no success. I got the Cyclone initially as I thought I'd gotten the best out my old faithful TC3 but since getting the Cyclone i think I've lost nearly 1/2 a second a lap!
I had the original chassis to begin with but moved to the BMI one a few months ago.
No matter what I do the car either just doesn't turn in or it just seems to almost stop mid corner (no traction compound as it's not allowed at my club). At least with this set up I seem to have Ok mid corner steering and it's easy to drive.
here's my set up:
Front:
- camber 2
- castor 6
- ride height 5
- droop 7
- toe angle 1
- toe block 2.5
- 2.5mm under camber link -
- inside cmber position 4
- no roll bars
- position 2 on shock tower
- 25lb spring (associated)
- 50wt oil
- 2 hole 1.1mm piston
- diff
- no roll bars all round
- GRP 42 Shore 59mm
rear:
- camber 1.5
- ride height 5.5
- droop 5
- toe block 1
- 2mm under camber lonk
- position 4 on shock tower
- 35lb spring (associated)
- 40wt oil
- GRp 37 Shore (59mm)
ackerman 3
Mazda Speed 6 shell
I've done everything I can to get more steering and the set up looks a bit extreme now. I hope someone can help as I've tried a few set ups including one's from Hara, Andy Moore and Marcos' without success.
Cheers,
Jason
here's my set up:
Front:
- camber 2
- castor 6
- ride height 5
- droop 7
- toe angle 1
- toe block 2.5
- no roll bars
- 50wt oil
- diff
- GRP 42 Shore 59mm
rear:
- camber 1.5
- ride height 5.5
- droop 5
- toe block 1
- 40wt oil
ackerman 3
Mazda Speed 6 shell
Cheers,
Jason
Are you runing on carpet or ashphelt? foams or rubbers?
It sounds like there must be something on the car that is jamming or mechanicly not functioning properly or not full steering throw etc..., It has to be something,
Try being nice to a real fast guy at your club and ask him to check over your car when he has time, this might help as there has to be something wrong with something, because this car has won the world championship in 2006!!!!!
It's foams on carpet.
I know it's won everything and I'm completely stumped myself! It's running free, servo's free and has good speed, torque, centre's perfectly everytime (KO 2314), drivetrain's smooth, nothing's broken or bent, it's not tweaked, turns equal left/right, balanced left/right, front/back.
JL,
first thing i noticed in your setup was the front caster at 6deg will reduce the steering response. perhaps try going back to the 4deg (standard) or go one further to the 2deg blocks.
Also, I notice on your setup your running a mazda body and tires that you wouldent find on a setup sheet. When copying a setup it is very critical to copy the entire thing, something such as the wrong body can really throw it for a loop. There are alot of great setups for the cyclone and I am sure that when followed to a T there is one out there that will work for you. Often times without alot of setup knowledge people go chasing and get themselves so far out of tune there is no way there going to be fast. At that point the best thing you can do is start over with a proven setup.
If it was me I would look for something that larry f or jason s ran at the IIC 2 years ago and go from there. Also macro's probally has a solid starting point for you laying around somewhere.
Also just noticed your running stiffer springs in the rear. It appears as if your setup is so far off its just not going to work. Start completly over! You are way off track right now.
Good luck.
Good luck.
yeah whats with the super stiff springs on the car?
I havent raced on proper carpet with foams but i found that when i was racing the cyclone didnt seem to like stiff springs, although most people say to stiffen up the car.
1 degree rear block ive never seen anyone run one that small. Id stick with about 2.5
Also i personally find 4 degrees castor is standard on almost everycar, not sure who runs 6, but i guess that could be a carpet thing **SHRUG**
Also what are you running up front, ball-diff and what motor are you running?
Super Moderator
hi, may i knw how u guys make d left n right weight is even ?how u guys weight d left n right ?
thanks
thanks
I hope you under stand me and this helps you
Russ
Some Gossip.....
Hara was testing 3 Clones this week at RCS; one virtually standard, one with a new chassis, one with a new upper deck and middle brace. All were running the new diff. No update on the release date of the new car... still due around the Worlds....
Sorry, no photo's... (I asked, but he wouldn't let me )
PS> Adachi Shinosuke, Neils Keonekoop, and Oscar were also there this week practicing with there Kyosho's .
