Hot Bodies Cyclone
#2566
Originally Posted by wyd
I ran into my first problem. I built all my shocks but I have one where the threaded retainer will not thread right. It is so tight once you get it started that you can't tighten it any farther. It is not cross threaded and I already tried all the other retainers on this shock and the same results. It seems like maybe the hard anodize might be a few mils thicker and causing the problem.
I just ordered some new bodies and extra retainers. Stormer Hobbies had them all in stock so I should still easily be good to go for next weekend.
One other note is Rayspeed Springs fit thse shock perfectly. I had all the springs from when I ran them on my Cuda and Yokes. Just one more tuning option available for those that have these springs. I decided to use these instead of order a set of HPI springs at this time.
#2567
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by Skill
I also had this problem with 2 of my shock bodies. You just need to gently persuade the shock collar onto the threads, by turning it forward and backwards. Gradually it will move up the shock body and after that it should be fine, it took me a few minutes to do this but it's better than buying new parts
That was the only problem in the kit. For those who want to try Rayspeed springs they are about 2mm longer than the stock kit springs. I had no problems getting my 5mm ride height with these springs and rubber tires. I went with the Red springs for the front and whites for the rear like I did on my Cuda's. Car feel really nice. I'm in the finishing stages now. Just put in electronics and need to adjust them and then put on my new lid and its actually ready to test on the track.
#2568
Anyone got any ideas when is the release date for Hara's edition of cyclone with all the purple parts....
Bling bling.......
Bling bling.......
#2569
What belts are you lot running in your cyclones? has anyone found any that help free up the drivetrain alittle more??
#2570
Tech Legend
#2571
Hey Jason ........... how did your racing go this weekend ? Chaulk up another win with your Cyclone ?
#2572
Originally Posted by JoeyE
I rebuilt my shocks with TAMIYA bladder(cuz I had some laying around)and the work fine. I don't like the little foam thing that sits on top of the bladder so I used two o-rings instead. Pretty good now Also got the Square right bulk head peice. Looks like an MSX, haha.
also the foam on top contributes to rebound, so changing it to 2 o-rings along with the tamiya bladder will give you WAY less rebound dampening than normal. the hpi foam is very soft (mainly compared to tamiya red urethane).
so if your car is porpoising or unloading a corner too quickly you may look into changing that.
#2574
Anyone have more info about the Hara and Karn version Cyclone. Is it a limited edition or is it a direct replacement?
#2575
I think this summer.
#2576
Originally Posted by m8commando
Anybody know where I can find cylone parts, i need 2 front axels.
Try RcModel. I have ordered most of my parts from them.
http://shopping.rcmodel.hk/
#2577
Well about 65% done with the car. Everything is very smooth. Only problem is I broke 2 ball studs so far as they seem to split easily if you tighten them up too tight (I actually didn't think it was that tight but apparently it was). No big deal as I will just order a few more.
BTW ran in the florida state series this week end and ran well no problems at all and I have to say that the car is extremly stable with double oneways. I Ran the Hara nats set up (the race was at speedline hobbies) I just showed up and put the car down, I didn't have to change a thing. I felt good and I haven't been this competitive in a while infortunately the rust from not racing in a while got to me and I didn't finish well. I didn't have any relivility problem to speak of and I'm very happy with the car.
Jason it was a pleasure to meet you, Again let me know if their is anything I can help you with. Im going to see if I can make it out to B&B sometime before next ST race. Thanks again for the set up nuts Ill be puting those things to good use.
Luis
#2578
Trader Rating: 22 (100%+)
has anyone had massive understeer with their cyclones with the kit setup. Despite what changes I make to car (and I have had help from HPI) I still get major understeer. I am thinking I have built something incorrectly.
Any help?
Any help?
#2580
Any help?
Any help?
Something must be wrong, I would go over the whole car with a fime tooth comb. I found my self tuning out steering with the stock set up and this was racing with a front diff and loked center pully.
