Hot Bodies Cyclone
#2416
Originally Posted by JoeyE
Last night I bought the front spool($34!). It works great with the stock bones. At least for now
#2417
Originally Posted by nordheim
After snapping the axle on my TIR CVD's with the spool in and bending the original aluminum bones, I went ahead and took the advice on the Tamiya universal 42mm steel bones. They seem to work perfect and haven't bent so far. The other advantage is that they're pretty cheap ($13 for the set) compared to $18 a piece for the TIR axles!
#2418
Yep, it's a direct fit with the Cyclone outdrives. Part number is TA-53501. Tower has them and RcModel has them too.
http://shopping.rcmodel.hk/product_i...oducts_id=1411
Do you have the part number for the TAMIYA bones? Thanks~! Direct fir with the Cyclone outdrive?
#2419
recently tir seem to have been going through a bad batch of products, last year i know people that were running lower turn motors than 12 with them and that they were hardly wearing atall (in a different car). but recently i know people that have been running them in 27t and the pins wear out after a few weeks. i think that you should contact tir directly and ask them about this problem.
#2420
[/QUOTE]
Use the Tamiya outdrive ...fit better with dem
#2421
Do you have a link to them ? can you buy it at rcmodel ? a part nr. would be great also ?
#2422
Despite the problems with people have been having with the TIR CVDs I still think they are the best you can get by far. Yes I did break an axle on mine with the Pro 4, but I did get a free replacement, TIR stick by their products! You can break any part if you are going fast enough or if you hit something at the wrong angle, but all I know is that in the period of about 9 months in which I had my CVDs on the Pro 4 there was NO wear at all on the pin holes and they still ran as straight as new.
#2423
Originally Posted by protc3
Does this mean there will be a BMI chassis for the Cyclone?
[/QUOTE]
How soon will it be available? The carpet nats are coming up quick.
#2424
On an other durability related issue: I have been braking the heads off the ball studs lately, 4 in the past 2 races. Unhappy with their strength, or lack of, I wanted to buy the Ti ball ends the Square made, but are no longer available. SO I had to find an alternative, I searched the parts wall for anything that would work I ended up using Xray ball ends and Ball Joints (not exactly cheap) the part #’s are as follows:
30 3222 ball joint 5mm unidirectional – open
30 2650 5mm ball end with thread
For the steering bellcrank I’m using a 30 7454 5mm pivot ball double shoulder and a lond screw because the treads are too short on the ball ends to properly maintain the spacing for the ackerman setting. A big plus is that I can now use the outside setting on the rear hub because the joint/ball combo has a lower profile than the stock set up, even if you use Shumacher cups. Also the height of the Xray ball is identical to the HPI one so it wont change your roll center setting.
#2425
Because they're available in my LHS, which is not the case with the Cyclone steel pieces. The fit may be better if you have the Tamiya outdrives as well but it's hardly noticeable that they're a little shorter than the stock Cyclone bones.
Originally Posted by pucho
Why bother with the Tamiya parts HB has their own harden steel pieces, I have been running the since day one with great success.
#2426
well,ran my cyclone for the first time today.what a joy it was.i ran layshaft and front one way.the car was on rails.tons of steering yet still stable.the car carried tons of speed through the coners and was extremely predictable.
I TQ'ed and won the A main in 19 turn and also won 1/12th. i am very happy with this car.however,i did slightly bend my front cvd.does anyone have the part # for these good cvd's that your talkin about?thanks in advance
#2427
HotBodies steel front swing shafts #HB61043
unlike the alu shafts, which come as a single unit, the steels come in pairs
#2429
#2430
Tech Legend
Trader Rating: 51 (100%+)
thanks buddy
Jason how does the car feel compared to some of the other touring cars you have ran in the past few months?
