Hot Bodies Cyclone
well i cant really say im looking for a different top deck just a different design because the place where it breaks is very weak.
Super Moderator
Super Moderator
now i remember i did have a crack one in that spot a year ago and it was due to a bent bulkhead in the front, when i installed the new top deck it wasnt aligning properly and it was adding extra stress to it, might be a long shot but try that 1st
http://www3.towerhobbies.com/cgi-bin...?&I=LXNZG5&P=7
so this being bent the slightest bit is making this happen?
Whats the biggest spur I can fit being safe with the stock motor mounts?
I want to do a 105, or 106, will this hang out the bottom of the chassis? Or am I safe?
Super Moderator
Super Moderator
110 spur fits just fine it sticks out of the chassis about .010" i ran it for a year no problems at all 108 fits with no worries,you are safe with any of those
Super Moderator
Super Moderator
the foam car has the 108 spur and the other has the 110 (hpi spur)
No no, I didnt mean it that way lol
I mean FDR wise, I dont want to order one because every time I have tried from my track, he cant get anything bigger then 47, and I want to stay in the 4.8/9 range
BTW, nice messy wiring
Trying to set up a spec electric series at our club based on the Cyclone RTR - I need a few questions answered to tighnen up the rules. Any answers you could give me - or better yet a contact at HB to whom I could send these questions to would be appreciated (contact link on their site is an empty page).
Cyclone RTR
What wheel/tires does it come with?
What would you spec as a comparable replacement?
What servo does it come with?
Would a Futaba S3004 be a comparable replacement?
I assume that it comes with a silver can (540), can this be confirmed?
Cyclone S
Is this chassi identical to the RTR minus the electronics and paint?
General
Any comments on the weak links of the RTR so that I can get my LHS to load up on commonly broken parts?
Any comments on the feasibility of taking the RTR - upgrading the electronics / tires / bodies and running in Stock Rubber class?
Cyclone RTR
Cyclone S
General
First the kit C hubs are rubbish, get rid of them and replace them with Carbon Graphite. You dont want people breaking them on their first meet and getting discouraged (which is a high probability). I would make the change mandatory :P
If you allow people to build up the cyclone S from scratch there are a couple of build issues you should be wary of with the diff halves and the shock bodies so make sure you find out about that.
Finally you will find that a 540 motor isnt ideal in the car as the bottom vent is covered by the chassis. The motor will tend to get hotter than it should.
I personally would give people the opting of removing the motor guard on the side and then put in a $10 motor spacer to move the can out a few mm.
Super Moderator
