Xray T1FK05
#3391
Originally Posted by Scho
A bucket full?
Wont last very long, try a skip full
a bucket is enough for us...maybe its your driving that requires a skip full
#3392
#3393
ouch lol that was funny
#3394
Originally Posted by stonedgti
It slows down the transfer rate from side to side, thus giving you slower steering response. If the front of your car is reacting too fast on steering response, you can lengthen the linkage.
#3395
Originally Posted by Midnight
Thanks, is this the same theory for the rear also. Im running a short link now with a 2mm shim under the hub carrier. I forgot to mention that Im running anti dive in the front. Mid in the front and lower in the rear on the front of the car. Once again thanks for any help.
I believe the same is true for the rear. Longer links normally means a more stable and forgiving rear end to abrupt steering inputs.
#3396
If I dont use the kick up the car seems twitchy ( touchy), what Im looking for is a way to keep the rear end planted and stop the car from spinning out. I tried stiffer springs (25) but it seems to make it more touchy. I thought about going from 22.5 to 20 but was afraid of traction roll.
#3397
#3398
I'm thinking that maybe the kickup is allowing the entire front end to dive and take more time for the weight to be transferred forward. In effect its slowing down the initial steering up front and allowing the rear end to catch up and not become unloaded.
#3399
From anyone else i would laugh along... But not from the most random driver in the world
#3400
You mean you actullay replace the blades Matt?
Dosent that cost? LOL
#3402
No he's to busy picking the rest of his car up!
#3403
I need to know how to pick up more mid corner steering. I like the turn going in and I like how it comes off the corner. The only problem I have is a slight push when picking up the throttle mid corner. I don't want to lose traction on exit and I really don't want the car to turn in harder it's just that split second mid corner when you first pick up the throttle. Someone suggested shortening up the front camber links to give more camber change for more mid corner steering. Does that sound right or is there a better adjustment first?
#3404
if your still using the stok springs you could change the springs to light blues in the front and whites in the back that should give u the steering you need
#3405
Trader Rating: 21 (100%+)
