Like Tree1Likes
Xray T1FK05
Old 08-27-2005, 05:41 PM
  #3361
Trader Rating: 18 (100%+)
Is anyone here using tamiya shocks?? Can some one tell me what pistons and oil to use for mid to large some what tight track..thanks
Roberto Falcon is offline
Old 08-27-2005, 10:20 PM
  #3362
lbckevin's Avatar
Trader Rating: 106 (99%+)
Sorry, dont use Tamiya shocks.
lbckevin is offline
Old 08-27-2005, 10:32 PM
  #3363
Hi I have got a FK05. Can anyone please help me why do my car keep skidding in coner?
N15M0 is offline
Old 08-27-2005, 11:11 PM
  #3364
gee-dub's Avatar
by skidding to you mean to a stop, or spinning out?
you're going to need to give a description of your setup (including tires) as well as the surface you are running on. all things being equal, if you're running the kit setup and your car is spinning (and your tires are in 'ok' condition), the first thing i would be checking is that the tires have not come unglued from the rim.
gee-dub is offline
Old 08-27-2005, 11:20 PM
  #3365
HarshGuy's Avatar
I'm using 3 hole and trinity 45 wght oil ...this is for asphalt medium to high bite tracks.
HarshGuy is offline
Old 08-27-2005, 11:53 PM
  #3366
I mean spinning out. The tire are guled properly and they are quite new. I am running on road surface. The setup are according to the menu.
N15M0 is offline
Old 08-28-2005, 02:26 PM
  #3367
Roger's Avatar
Default Foam tires
Whats up guys. I tried so mount up some jaco foams to my FK05 and the noticed that the my rear foams are hitting the lower shock plactic mounts. Do I have to grind down the plastic in order for clearence or is there something i should do to run foams ? Thanks for the help.
Roger is offline
Old 08-28-2005, 02:29 PM
  #3368
scoobydo's Avatar
If I remember correctly, In the manual it instructs you to shave off a piece of the arm if you are using foams.
scoobydo is offline
Old 08-28-2005, 02:48 PM
  #3369
Roger's Avatar
Thats right. I remember reading about that. Thanks.
Roger is offline
Old 08-28-2005, 04:15 PM
  #3370
r0adrunn3r's Avatar
I just put some spacer washers between the wheel axle hex hub and the inside of the foam wheel. It moved it out far enough to clear it.
r0adrunn3r is offline
Old 08-28-2005, 05:04 PM
  #3371
howard hudson's Avatar
Loosen the rear diff sounds like it is to tight. I had this same problem and was chassing set up after set up. It got to the point where i was going to get rid of the car and just run the fk 04. but then I had a conversation with one of my sponsors (BMI) and he said the Magic WORDS " have you checked your diff?" Thats the only thing I never touched. Made it looser and the car is hooked up now. As long as I have been doing this hobby I should have known better.
I feel kinda dumb now
howard hudson is offline
Old 08-28-2005, 05:11 PM
  #3372
Slingblade's Avatar
Default shocks...
I am thinking of buying a xray t1 05 fk and i was wondering how the stock shocks compare to the flouride tamiya shocks. Are the tamiya ones worth the money for an upgrade for the xray car? Do the o5 fk kits come with a multidiff? Where is the best place to buy online since xray is not supported locally. Moving to San Diego in the spring. Does socal raceway suport xray?
Thanks in advance......
Slingblade is offline
Old 08-28-2005, 05:22 PM
  #3373
BigDogRacing's Avatar
Guys ask the same question every year at the beginning of carpet season...lol
Roger, take your dremel and simply cut off the boss where the shock screw mounts. If you are anal like myself, start at the end closest to the chassis where the boss meets the arm and cut it parallel to the original outermost surface so that the shock ball and end still mount perpendicular to the centerline of the chassis as opposed to cutting the boss down flush to the arm. My way leaves a little extra meat for the screw but still gets it in deep enough to miss the wheels. Also, if you move it too close to the arm you will notice the spring perch rubs the upright and you'll have to grind a smooth spot on the upright to stop that from happening.
Hope that helps...
BigDogRacing is offline
Old 08-28-2005, 05:32 PM
  #3374
axel's Avatar
The xray shocks work just fine, but I myself plan on switching to the tamiya shocks. All kits come with the multi-diff EXCEPT THE U.S. VERSION. Speedtechrc.com I like speedtechrc.com for online shopping, but since all my LHS carry xray parts there is no need for me to use online shops.
axel is offline
Old 08-28-2005, 05:52 PM
  #3375
hpipro321's Avatar
lbckevin Sorry, dont use Tamiya shocks.
ya do not use the tamiya shocks ppl at my local raceway tried them u need a lot of modding to the arms and special parts its really not worth it
hpipro321 is offline
