Xray T1FK05
#3541
Originally Posted by IN10CT
i was wondering what does the wide upper deck do to enhance the performance? or is it all just for looks?
High-quality CNC-machined graphite upper deck for XRAY T1FK’05 is wider than standard #301164 upper deck for increased chassis stiffness; for high-grip conditions especially foam/carpet racing. Designed with two extra rear mounting positions for #306510 Alu Top Deck Mounts. Includes composite bearing holder.
To set a ultra stiff chassis, it is suggested to use this wide top deck and the #306510 Alu Top Deck Mounts both in front and rear.
#3542
And it gives the flexibility to change the stiffness of your car very simple.
#3544
Originally Posted by c-lyon
My P-Dub and XRAY bumpers both weigh 14 grams.
CaptMicro- yes, that is where I have run my Transponder for quite some time now. It keep the CG low and there is no CF under it to not pick up the laps. I think I saw one of the cars in the last TC Mag like that so tried it and it works good.
IN10CT- I use the wide upper deck for the same reasons Joep does. Flexibility and tunability. On Carpet with foams, you need all posts and 3mm chassis like this car has. For pavement with rubbers I still use it but take out the posts.
JAMESCAM- I will take a few photos here soon and post them for you.
Thanks for the comments.
#3548
C-Lyon, Yeah, I dont get that at all?? Both of mine weigh the same also? Both stock ones are 4 grams.
, Does anyone have one of the blue stock ones? If so, how much does that weigh?
The ESC wires are just run along the chassis so they look short. I didn't want to cut them. The servo I just cut the wires in the middle and resoldered them together. Same with PT.
#3549
#3550
Originally Posted by hpipro321
it reduces flex within the chasis
#3551
Hi
To all that have that have kindly purchased Cool-Can-Fan's for their cars. We now have a NEW L
K website
Cheers Malc (The-Cool-Can-Fan-Man)
www.coolcanfan.com
www.coolcanfan.com
#3552
Originally Posted by Trakside Trucke
Hi
K website
www.coolcanfan.com
www.coolcanfan.com
#3553
could the wide upper deck be used on the Fk04 or just the FK05?
#3554
#3555
ok thankyou
