Like Tree1Likes
Xray T1FK05
Old 08-29-2005, 04:48 PM
  #3406
the_barbarian's Avatar
I really belive Hudy make most of their money from the blades even in stock they wear bad and one hole always breaks
come on Hudy lets make these pethetic little parts cheaper and stronger
for what they are you should be able to by a bucket for $20 but instead you get 4 for $4 thats f#@king rediculus
the_barbarian is offline
Old 08-29-2005, 04:55 PM
  #3407
hpipro321's Avatar
corally cars use them 2 maybe theres are cheaper havent cheked
hpipro321 is offline
Old 08-29-2005, 05:24 PM
  #3408
hpipro321's Avatar
just looked the corallly ones are a dollar cheaper so u get 4 for 3 buks thats a deal
Old 08-29-2005, 05:41 PM
  #3409
and these are the same are they ?
with the pricing of corally parts I thought it would be dearer
so there you go Hudy even Corally make the blades cheaper lets start dropping the price 25c each would be fair
Old 08-29-2005, 05:49 PM
  #3410
howard hudson's Avatar
oh come on guys!! quite cher bitching. How often do you have to replace a arm after hitting the wall or replace bearings cuz they are to small to handle the stress ??? This car is tough so stop about the plastic caps
how about they just stoppped useing them completly so the diff halfs wear out or the drive axle pins wear out? that would be better
howard hudson is offline
Old 08-29-2005, 06:40 PM
  #3411
dado11g's Avatar
from driving xrays for 2 years, i still havent hurt one blade
dado11g is offline
Old 08-29-2005, 06:41 PM
  #3412
how about making them a reasonable price come on
Old 08-29-2005, 07:04 PM
  #3413
John Tag's Avatar
Trader Rating: 42 (100%+)
If your not changing your front blades you probally not running a spool or going fast enough..LOL I run a spool and change them every 2 weeks so the $2 is nothing every 2 weeks for 2 blades.
John Tag is offline
Old 08-29-2005, 07:15 PM
  #3414
corally blades are a different size than the Xray.
DJG24 is offline
Old 08-29-2005, 08:09 PM
  #3415
Trader Rating: 14 (89%+)
Have the same problem with the blades when running a spool. With anything else they seem to last pretty long. With a diff I hardly ever have to replace them. I think that is better than breaking or wearing out other parts. The price isn't bad at my LHS. Overall the Xray is a great piece.
dmayhew25 is offline
Old 08-29-2005, 08:14 PM
  #3416
m8commando's Avatar
especially when you get it for $200.00
m8commando is offline
Old 08-29-2005, 08:38 PM
  #3417
$200 That would be nice!! They do have some good prices though.
Old 08-29-2005, 08:40 PM
  #3418
m8commando's Avatar
with a multi diff and a battery brace.
Old 08-29-2005, 08:46 PM
  #3419
When are you going to make the trip back up?
A question to everyone,
How do I get my car to the Vegas weight limit? I have the following and am still about 40 grams over???
Xray 05
3mm chassis
wide top deck
all 4 posts in
diff front and rear
Jaco Foams, 28mm
Airtronics 358 Servo
LRP Q2 w/ worlds kit, lg cap.
JR RS310 Reciever
PT
P-Dub front bumper
Batter brace, would like to keep if possible
GP3700 batts.
I just ordered the Ti bolt kit to help lose some lbs. but do you think that is going to be enough? Any other options I might be able to get to help lighten the car? Thanks for any help.
Old 08-29-2005, 09:03 PM
  #3420
teamgp's Avatar
Originally Posted by DJG24
I need to know how to pick up more mid corner steering. I like the turn going in and I like how it comes off the corner. The only problem I have is a slight push when picking up the throttle mid corner. I don't want to lose traction on exit and I really don't want the car to turn in harder it's just that split second mid corner when you first pick up the throttle. Someone suggested shortening up the front camber links to give more camber change for more mid corner steering. Does that sound right or is there a better adjustment first?
You might also try raising your front downstop setting up .5 to 1mm or using a little anti-squat with the new .75 suspension holders with the rearward mounting position of the rear arm hinge pins.
teamgp is offline
