RC Crew Chief Software >
Like Tree91Likes
Old 07-31-2025 | 06:46 AM
  #916
LOWDRAG when I get home I will post up. I have the x4-25 car like 95Percent modeled.
jmrcracer is offline
Old 08-15-2025 | 10:03 PM
  #917
Default xray t4-25 car
Version 3
62,24,4.5,-1,8,4.5,61,19,38.5,48,30,14.5
7
W 0mm,0,0
W 0.5mm,0,0.5
W 1mm,0,1
W 1.5mm,0,1.5
W 2.0mm,0,2
W 2.5mm,0,2.5
W 3.0mm,0,3
x-ray t425,1322,112.4,103.2,-3,0,28.5
0.021,0.7,0.078,-0.25,85,0.1
1/10th 190mm 4wd Electric Touring Car
john chassis,256,188,188,85,1.5,38,88,0,0,0,0,1.9,0.45, 6,93
1/10th 4wd electric Touring Car Chassis
7
O 0.0mm,0,0
O 0.5mm,0,0.5
O 1.0mm,0,1
O 1.5mm,0,1.5
O 2.0mm,0,2
O 2.5mm,0,2.5
O 3.0mm,0,3
6
1.5mm,0,1.5
2.0mm,0,2
1.0mm,0,1
0.5mm,0,0.5
0.0mm,0,0
2.5mm,0,2.5
0
50,50,-2,0,30,26,33,29,0,2,3,2,5,False
True
32.75,5,10,5,7,4,1.5,10,18,3,1.6,3,1,1,True
1
4 x 1.1,4,1.1,9.86,1.85
62,24,4.5,-1.5,8,4.5,61,19,38.5,48,30,14.5
7
W 0.0mm,0,0
W 0.5mm,0,0.5
W 1.0mm,0,1
W 1.5mm,0,1.5
W 2.0,0,2
W 2.5,0,2.5
W 3.0,0,3
7
O 0.0mm,0,0
O 0.5mm,0,0.5
O 1.0mm,0,1
O 1.5mm,0,1.5
O 2.0mm,0,2
O 2.5mm,0,2.5
O 3.0mm,0,3
8
3.5mm,0,3.5
3.0mm,0,3
2.5mm,0,2.5
2.0mm,0,2
1.5mm,0,1.5
1.0mm,0,1
0.5mm,0,0.5
0.0mm,0,0
0
50,50,-2,0,30,26,33,29,0,1,3,2,8,False
True
1
6
C2.5,2.5
C2.6,2.6
C2.7,2.7
C2.8,2.8
C2.9,2.9
C3.0,3
6
Front Soft,1,24,0.2914854
Front Medium,1.2,24,0.3920627
Front Stiff,1.3,24,0.5166643
Rear Soft,1.1,26,0.181
Rear Medium,1.2,26,0.235
Rear Stiff,1.3,26,0.298
Steering
0,5,27.5,8,9,27,27,18,54,57,-1,4,0,0
0
7
1.0mm,0,0
1.5mm,0,0.5
2.0mm,0,1
2.5mm,0,1.5
3.0mm,0,2
0.5mm,0,-0.5
0.0mm,0,-1
0
1
base,38,88,0,0,0,0,1.9,0,0,,,
0,0,0,4.5,-1,62,24,2,3,350,,,,1,0
0,188,3,3,1
0,0,0,4.5,-1.5,62,24,1,3,350,,,,1,0
0,188,3,3,1
Steering
-1,4,0,45,0,0,0
Old 08-15-2025 | 10:04 PM
  #918
sorry for the delay had a hospital scare in between time. I hope this helps. I know its not perect but its close enough.
Dan the Man likes this.
Old 09-03-2025 | 01:08 AM
  #919
Default B7 front suspension - c hub
Hi, I have modelled the AE B7 in RCCC.
in reality, when adjusting “axle height” at the front the wishbone outboard lower and upper pickups essentially change height together relative to the ground. In the software when I adjust the lower hub position, should I also adjust the upper position in the same amount, and direction? Or
is this allowed for within the software and it assumes the car has a C hub?
.DPR. is offline
Old 09-07-2025 | 12:41 PM
  #920
Good Afternoon,
I feel that I have followed all of the directions in this thread, but I obviously have not somewhere. Can someone help me by chance. I can get to this screen, but I can not click on anything. It is all greyed out.
jman4210 is offline
Old 12-05-2025 | 02:13 AM
  #921
Just heard of this program and thanks to you guys, I now have it working. Amazing work he did.
Now, all I need is a model for the XRAY X4 2026 and XRAY X5 2026, does anyone have this models? Or can guide me on how to make the model, as I have both cars.
clauslyhne is offline
Old 12-08-2025 | 12:55 AM
  #922
Pharane0's Avatar
the rc crew chief youtube channel explains how to take measurements to make your own model
Pharane0 is offline
Old 12-22-2025 | 08:46 AM
  #923
How do you guys download the software now?
AlbinP is offline
