RC Crew Chief Software >
Like Tree91Likes
Old 09-13-2019 | 04:50 PM
  #766
massenb203's Avatar
BobW, do you plan to add the diff height effect.
massenb203 is offline
Old 09-19-2019 | 08:02 AM
  #767
BobW's Avatar
To include the effect of diff height requires the torque being delivered to the front/rear wheels to be added. This effect is a function of the tension in the belt and the height at which it is reacted to the chassis. There may be a gyroscopic effect as well but I would think it would be small. So the short answer is it is unlikely to be added as the program as extensive modifications would be required.
BobW is offline
Old 09-19-2019 | 11:06 AM
  #768
massenb203's Avatar
Thanks Bob for the reply.
Old 09-19-2019 | 12:05 PM
  #769
Marcos.J's Avatar
Super Moderator
Does this software calculates ( specially outdoor tracks) things like ambient temperature,track surface temperature , humidity , track conditions ,is the track sealed asphalt or regular asphalt, is it a surface like a tennis court? if the track is Dusty,traction levels?
Marcos.J is offline
Old 09-19-2019 | 03:33 PM
  #770
LzREngineering's Avatar
That would all be part of tyre simulation, which the software doesn't do.
You can change the temperature to see the effect it has on damping.
Also you can change the simulated amount of g-force the car is experiencing in a corner but you have to work it out or measure it yourself.
RC3 is not really a complete set up simulation but it's a great set of handy tools for getting suspension values & other things
LzREngineering is offline
Old 09-19-2019 | 03:42 PM
  #771
Marcos.J's Avatar
Super Moderator
But can’t simulate the track that you are actually racing at. Thanks for the answer
Marcos.J is offline
Old 09-20-2019 | 12:02 AM
  #772
Even if it did, you can't just calculate track conditions, you have to go out and actually measure them, then load that data into a sim.
Old 10-06-2019 | 09:21 PM
  #773
Hi Bob,
since the software demystifies the science behind allot of the car physics have you considered adding some things around track data?
for example you can measure a track length and time to run a lap. A traction factor can be calculated or measured by the difference between actual and theoretical or telemetry.
if you know the motion profile of a lap you can calculate the torque/rpm requirements for each section or the whole lap
if you know efficiency for each point of the torque curve you can calculate waste heat. You can measure the average temperature at the end of a race and if its less than the predicted then you specify gearing that moves the average rpm away from the efficiency average towards the power peak and vice versa if its too hot.
The difference between theoretical heat and actual is the cooling efficiency of the setup. You will have generated a thermal time constant that can be used to modify convection versus conduction or changes in ambient.
after you correct thermal and traction calculations you have constants that can be applied and used to take advantage of future changes.
a current/rpm curve of an unloaded motor can be applied as a power measurement of a loaded chassis on track with a single factor to compress it by the rpms seen on track.
timing is primarily correlated to average rpm of the motor.
just a couple ideas of how to integrate track and chassis data into torque curves or create better starting points for gearing and motors.
Brushless motor science can use averages but because of heat they are really sensitive to each discrete section of the power and efficiency curve which comes from discrete torque/rpm points per lap.
LzREngineering likes this.
Bry195 is offline
Old 10-07-2019 | 12:07 PM
  #774
Just noticed a very strange bug: whenever I save a setup, the rear track width reduces by 0.2mm
Over time this has taken about 5mm off one of my setups leading to some very strange numbers!!
Old 05-14-2023 | 08:19 PM
  #775
EDWARD2003's Avatar
It is with deep sadness to let you all know about the passing of Bob Wright - BobW.
There are no words to describe how much he loved this hobby.
Rest in peace, Bob.
EDWARD2003 is offline
Old 05-14-2023 | 09:40 PM
  #776
h2e's Avatar
h2e
I share your feelings, Edward. He was a real jewel for the hobby, always up for a deep dive into rc science. My condolences.
EDWARD2003 likes this.
h2e is offline
Old 05-15-2023 | 01:48 AM
  #777
This is very sad. I built my own dyno using Bob's information and he was very helpful when I was having issues.
He will be missed.
Dave
NZDave is offline
Old 05-15-2023 | 02:48 AM
  #778
daleburr's Avatar
Rest in peace, Bob.
Sad news indeed. I used his Rollcentre Calculator before it became RC Crew Chief.
Bob was a very smart and helpful guy, two things that don't always go together.
daleburr is offline
Old 05-15-2023 | 09:41 AM
  #779
erchn's Avatar
Oh man, this one hurts. Bob was always helpful, always kind to this entire community. I wish his family well, Bob will certainly be missed. 😥
erchn is offline
Old 05-16-2023 | 04:11 AM
  #780
ntz
Very Sad news indeed. His creation and himself really helped me a lot in my first steps in the hobby. RIP BobW
ntz is offline
