Xray T3 2012
#141
Any idea how long until we will see the T3 2011 Spec R version? Soon I hope.
#142
I use the spec r clamps they have a much lower profile maybe 2mm lower they are just the ideal thing for my set up
#143
You confused me because you initially referred to all 4 positions (FF,FR, RF,RR) Yeah I saw the selection option for the rear but since the reason of going to the single blocks for the FR and RF was to strengthen the chassis I'm a bit skeptical that they would release an option that would circumvent that so I have to wonder if maybe that's an error on the sheet But maybe we will find out at some point
The clamps in the T3-12 have the same part number as the separately available ones, so I assume they are the same height.
#144
just checked the manual upper clamps are 1mm lower than what they've sold us as an option...
#145
#146
#147
They say put 1mm shim under inner camber links and front otherside same 1mm and rear 4mm shims like L1-L2 arrangement
I might be wrong but I guess 1mm lower ...
I hope that make sense
Cheers
Cheers
#148
Right, we need someone to; hurry up and get their kit, then measure the clamps for us
#149
possible ,they may want people start with h1-h2 height...
,I was thinking if we add some height to inner camber link we should also add some to outside...
extra 1mm over C hub and 1mm over rear upright is the recommended by Martin Hudy.
they might made a mistake there :/
well we should ask that on xray forums...
