Ta04r...
#271
Well Tamiya sells the short balls in steel and tower has them:
Tamiya short ballstuds
But I cannot find long ones anywhere.... guess I may have to retap the top of the steering posts and use titanium 4/40 units......
#272
New Tamiya parts
Tamiya Japan just announced aluminum center one-way, adjustable ball connectors for shock attachment and a set of the blue '04 hop ups.
http://www.tamiya.com/english/news/news/news0.htm
#273
Re: New Tamiya parts
If they have a new aluminum center one-way...what was the original center one-way made out of????
#274
hi all, i can get those all those blue parts for a good price, or any other TA04 parts.. let me know if interested.. thanks.
#275
Battery connections
Dudes,
how are your batteries connected on your R? I am using side by side packs, and I have to have one wire longer than the other. The longer wire is to connect to the battery pole which is on the same side as the pinion/spur.
So this is kind of a drag as the wires occasionally snap and it's a chore to rebuild'em - I need new wires. Can you guys tell me what's good and what you're using?
TIA!
Regards,
Alvin
TIA!
Regards,
Alvin
#276
um ....... try corally plugs / aka banana plugs if u r not using them already..
the wires from ESC must be longer and there are no wires on the battries so saddle packs have more room in their fitting slot
and wire ur battries so that the bridge from side 1 to 2 is stright and use SEVERAL LAYERS of electrical tape to cover up the solder joints so it does not get SHORTED OUT....
example ...
now u r using the bridge '|' to solder ur batts from side 1 to side 2
try using this
( the / is wire from top '+' to lower left - insteed of stright)
and use electrical tape on one or both sides which is facing each other
i bought 2 sets of banana plugs ( 4 male 20 female) around 1 year ago but i have yet to use it .... hehe
curently i m on deans which is not too suitable on saddle packs
example ...
try using this
#277
the second graphic SHOULD be
like this
the / wire should be soldered to opposite end of the + and - terminals so the wires should be STRIGHT in the middle when the packs are placed side by side .... and NOT BENDED in any way when its side by side
i have not tried this method yet ... but i figure it will work .. plz try it and tell me how it works ....
like this
#278
if u r using this ........
LOOK AT PIC ...
LOOK AT PIC ...
#279
change to this
look at pic ......
look at pic ......
#280
imaquito, you are using the carbon plate chassis correct? I'm still using a 99% stock TA04R with the carbon reinforced tub chassis, so I just cannot use saddle packs like you
#282
Thanks GKC.
Anyone tried the lightweight plastic diff joint? Are they durable? My 04's stock diff joints are beginning to wear out, there're grooves in t hem made by the universals. Wish there was something like the xray type diffs for our 04s.
~Alvin
~Alvin
#284
Great! You are right they are quite costly. Right now I am trying to reduce the weight of my chassis. It weights in right now @ 1.6kg, looking for ways to reduce weight. Must also save up for a new ESC to get rid of my 120g G12
But first getting the carbon f/r shock towers. Been playing around with the camber link locations and shock locations, the plastic's pretty worn out
Thanks dude!
~Alvin
Thanks dude!
~Alvin
#285
I've been running them about 3 weeks now...Well over 20 runs with a stock motor and they are showing no signs of wear...
If you are looking for a weight reduction, then this is the place...I weights the diff with the lightweight outdrive against the stock diff and the stock diff was about 2x the weight of the new diff and the car - at least to me - has a notable improvement in speed and acceleration People at me track have been wondering what I've been doing to the car to make it that much faster in a short period of time...I think they are actually starting to respect Tamiya now
