Team Losi JRXS
Old 07-13-2006, 10:20 AM
  #12121
TheCoolCanFanMan's Avatar
Hi
Is there any video footage of the touring car worlds like the 1/12 ?
Malc TCCFM
TheCoolCanFanMan is offline
Old 07-13-2006, 10:37 AM
  #12122
TLRacing
Todd Hodge's Avatar
Originally Posted by Evicerator
Hehe!
The only reason I'm CBin' is cuz I wasn't there to watch/race/help!
I figured you would of just drove there like the ROAR Nats??? I was waiting for you to show up.
Todd Hodge is offline
Old 07-13-2006, 10:47 AM
  #12123
The Evicerator
I was gonna install a hydrofoil on my Escape but I am a little short on funds because my roomate still hasn't paid up!
Otherwise I would have been there to throw down in the 2nd to last qualifier just like Nats!
Steve Weiss is offline
Old 07-13-2006, 11:50 AM
  #12124
Originally Posted by TheCoolCanFanMan
Hi
Malc TCCFM
Hi
Malc TCCFM
Old 07-13-2006, 12:33 PM
  #12125
theproffesor's Avatar
Trader Rating: 66 (100%+)
Just put some pics of my stuff for sale in the buy/sell section, here is the link, and a taste. http://www.rctech.net/forum/showthread.php?t=120586
theproffesor is offline
Old 07-13-2006, 01:53 PM
  #12126
PitNamedGordie's Avatar
Default Josh Numan Setup
I have been setting up my car to match the Josh Numan setup. I have a question about the front suspension setup. I have set the front roll center to high and I have added two shims under the pivot blocks (front and rear). In his setup he mentioned that he was using the BK blocks, as I am using the updated arms. My question is when I install my shocks and set the ride height and droop, my preload collars are all the way to the top of the shock, and the car bottoms at the same time the shocks do. Is that supposed to be that way? Did I install too many shims under the pivot blocks (he stated 2 .050" shims...I used 2 shims that were included with shim/block set)? I have shortened the shock length as far as possible also... I haven't driven the car yet, and it’s not a problem yet, but this seemed different from other cars I've setup. Thanks!
PitNamedGordie is offline
Old 07-13-2006, 01:57 PM
  #12127
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
youll have to shave the shock bottom, where the spring retainer sits. I think .060" should be plenty...
Keith Billanti is offline
Old 07-13-2006, 03:59 PM
  #12128
Hi
Malc TCCFM
Hi
Malc TCCFM
am i invisible
Old 07-13-2006, 05:47 PM
  #12129
TCR
So Todd was this Matt's last race, or will he make it to Vegas??
Originally Posted by T. Hodge
_Final B Cat. ISTC 1/10 -- 2^ Run Results
Pos. Driver Best Lap
1 1 Atsushi Hara 18.805
2 3 Hayato Matsuzaki 19.106
3 8 Graversen Steen 19.197
4 2 Pumpler Thomas 19.059 16
5 4 Ahoniemi Simo 18.968
6 5 Pavidis Mark 19.271 8
7 10 Francis Matt 18.564
8 7 Cyrul Josh 23.640 2
9 9 Kaerup Jonas -
10 6 Tosolini Chris 19.094 0
Notice MF's fastest lap in the B-Main. He backed this up with a 18.7.
TCR is offline
Old 07-13-2006, 06:19 PM
  #12130
mainracer's Avatar
Nope, no Matt for vegas
mainracer is offline
Old 07-13-2006, 06:25 PM
  #12131
POOKYT's Avatar
Hi
Malc TCCFM
am i invisible
Yo!!!!!!! Anybody seen or heard from Malc in a while?????? I can't believe he just dissappeared like that!! LMAO
I think I read a post where the video of the TC stuff was being edited and was to be sold by Ray Wood and some others. They may have had some lock on the coverage. Thats all I know buddy.
Brant
POOKYT is offline
Old 07-14-2006, 05:24 AM
  #12132
TLRacing
Todd Hodge's Avatar
You can either cut the shock bottom as Billanti had mentioned or you can run the high tower position. If you do run the high tower position you will have to move the camber link location down one hole.
Old 07-14-2006, 05:26 AM
  #12133
I just joined the JRXS movement. I sold me T2 and always wanted to try a losi for indoor carpet season. What is the most used setup sheet for stock? What mods should be done to better the car?
Its a med-hi bit track.
crazycraig is offline
Old 07-14-2006, 05:47 AM
  #12134
Brant
BOO there, that wasn't so bad was it
Its just that the 1/12 was on the orion site but the 1/10 touring car wasn't
Cheers Malc THE CAN MAN...........HERE AGAIN IN THE FLESH SO TO SPEAK
Old 07-14-2006, 07:05 AM
  #12135
TLRacing
Todd Hodge's Avatar
Are you racing on foam tire or rubber tire?
