Ask Steve "The Evicerator" Weiss
#6571
I didn't see an answer to this so I'll try again:
I have a question regarding the HV Maxx/Super Duty XR controllers.
When rewired to the single pack configuration, what is the maximum number of NiMH cells you can use (based on the BEC limit)? I know it has to be at least 7 cells because each will take 7-cell packs on each input when using two packs. Is single pack the limit 7 cells, or can they be run with 8 or 9? I'd be running a single high-torque Airtronics servo (94357 or 94757).
If the limits for the HV-Maxx and Super Duty XR are different, please let me know.
#6572
The Evicerator
Hello Ta_man,
Sorry if I missed your question before!
We recommend using a maximum of 7 cells on the ESC w/o the use of an external BEC. If you want to run 8+ cells you should use an external BEC.
This is true of both the HV and Super Duty Speed Controllers.
#6574
The Evicerator
With the HV pro, leave the plug that goes to the receiver plugged in.
Use the switch on the BEC to turn the car on and off.
When turning the car on, first turn on the BEC switch, next, turn on then off the ESC switch.
You are now ready to run.
When you are finished running, simply turn the BEC switch off.
There is protection circuitry inside the ESC that requires you to briefly switch the ESC switch on then off when using an external BEC.
#6575
#6576
The Evicerator
No, simply leave the ESC switch off and use the BEC switch to turn the car on and off
#6579
The Evicerator
Kevin,
No. The original GTBs did not have lipo cut off. When we came out with the SS GTB that is when we introduced the lipo cut off to all subsequent 6 cell GTBs after that.
#6582
The Evicerator
Catalyst is right. You SHOULD NOT use an AM, FM, or PCM radio system with a SPREAD SPECTRUM GTB.
You should only use 2.4 Ghz systems with the SPREAD SPECTRUM GTB.
Both the Spread Spectrum and Standard 6 cell GTB's we have been shipping for well over a year now have built in lipo cut off circuitry.
#6583
Hi Steve ,
I was wondering if the ORIGINAL GTB has the thermal cut off.
And also does it have lipo function , i think it has because when i received it their was the manual ( like always ) but also a small paper saying ATTENTION ! and it was telling how to activate lipo cut off or not.So i wonder if my original GTB has the lipo function.
Thanks Steve
Thanks Steve
#6584
The Evicerator
The original GTBs did not come with Lipo Cut off but all GTBs have had thermal shut down.
If your instructions came with material showing you how to turn on the lipo cut off, you might have a newer GTB than you think!
If you want to check for yourself, press and hold the setup button and see if you eventually get a red and yellow LED sequence. This will mean that you can change the lipo cut off either on or off.
Hi Steve ,
Thanks Steve
Thanks Steve
#6585
I know that i have a original version because it was much cheaper then the others.
So, it maybe has the lipo cut off.
Thanks Steve
