Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 03-11-2016, 08:07 PM
  #14686
tmail55's Avatar
Trader Rating: 61 (100%+)
Bert was focused on weight reduction.
tmail55 is offline
Old 03-11-2016, 10:58 PM
  #14687
I tried screwing the fan onto the heatsink at the fins the lazy way, just trying to self tap a 4/40 screw in there. I think it may work with a drill bit and some coarser screws.
The durability of that is debatale though.
nttdemented is offline
Old 03-11-2016, 11:16 PM
  #14688
So, this is what I found. Deciding between the third item on the list or the 2nd item and upgrade the fan to a Tornado.
Old 03-12-2016, 05:52 PM
  #14689
DARKSIDE's Avatar
this thread gets weirder ever visit....unbelievable
DARKSIDE is offline
Old 03-13-2016, 06:23 AM
  #14690
I've got this one on my 3 Diggity cars, works great.
Also comes in other colors if you like.
http://www.rcmart.com/ya0329bk-heat-...?cPath=1560_32
GimpyGolden is offline
Old 03-13-2016, 07:01 AM
  #14691
tmail55's Avatar
That fan mount looks KOOL!!!!!!
tmail55 is offline
Old 03-13-2016, 10:58 AM
  #14692
Wow that's perfect! Pair it with a Tornado fan and good to go?
Old 03-13-2016, 02:20 PM
  #14693
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Pardon the post, but I have a club racer NIB I bought as well as the DC4 conversion with the narrow chassis with intentions to build a "unicorn" project car. If anyone is interested in the kit, conversion or a combo please PM me.
RAL is offline
Old 03-13-2016, 08:34 PM
  #14694
tmail55's Avatar
RAL you have a PM :-)
tmail55 is offline
Old 03-14-2016, 01:33 PM
  #14695
Justwill, I just got my DCV's in today and started working with them. How far into the out drives did the bones go into? Mine are just barely getting in there with 1 degree of camber. Also, did you not need TC6 wheel hexes? The width of the axle is quite a bit thinner than the tc4 one so it won't clamp down and just wobble about. Not going to run the car like that for now as the front wheels are wobbling a bit on the bench even after tightening down the wheel nuts.
Old 03-14-2016, 01:36 PM
  #14696
Also for reference in cut the caster blocks like so for clearance.
Old 03-14-2016, 01:43 PM
  #14697
Here's a pic of it installed:
Not sure I could shim this out enough to get it in there as its shimmed on the inside bearing (between the bearing and axle stub) already to remove axle slop.
The drive is out a lightened steel diff.
I'm also missing the center crush tube that comes in tomorrow so that could change my clearances a bit but not by much I bet.
Old 03-14-2016, 01:58 PM
  #14698
Trader Rating: 19 (100%+)
I did the same thing and forgot to order the crush tubes.
I measured the stock hex and it was 5mm so I ordered the stock TC7 hex.
Hopefully I'll get everything installed and sorted out for the next points race this Sunday.
iTz Nicholas72 is offline
Old 03-14-2016, 03:27 PM
  #14699
Great. I'll get to ordering some tc7 hexes. Offset should be good I hope.
Old 03-14-2016, 07:03 PM
  #14700
TC6 VCS3 shocks built and mounted. Did 50 weight with gold springs front and 45 weight with blue springs rear. Tomorrow I do ball cups, turturnbuckles and turturnbuckle ends to replace the worn and heavy stocks and put the crush tube inside the steering blocks.
After that it's just tweak, ride height, droop and alignment adjustments and off to a test this weekend!
