Team Associated TC4
The First track is strict , its a Carpet track about 70' x 40 '( Fall- Winter). The Tc4 is the works OK there . Summer is their parking lot which is also good .
The Second track is Anything goes its a Huge outdoor asphalt 200+ ' strait that is where My Tc4 has the most trouble ( the FDR's they Run are from 3.0 - 2.8) Can't match their gearing with the Tc4's 2.5:1 trans. ( Yes I did dremel out the bracing under the pinion gear )
The third and forth ones are Hobby shop Parking lot tracks, which I found on RC Tech .
One of them has good racers with good equipment .(A Tc4 challenge) . and the last has good racers on a lower budget, VTA always a lot of fun there (a Tc4 Nirvana ).
Hi guys just bought a tc4 club, a 200 mm porsche body and some mikuni 5 mm offset wheels and the wheels fit right for width but the pocket the axle nut fits in does not have enough room for a tool to tighten it. Has anyone had experience with this? Is there a very thin wall socket? or do i have to find defferent wheels and from where? Thanks
Also you could check at your local hobby shop , With my TC3 I was able to find smaller nuts that fit the TC3 axle threads
I believe the ASC 2402 axles are slightly longer than the standard ones. Might help with getting a locknut on there.
To match the other racers 2.8 fdr gearing, you can use the Robinson 49tooth(48p) spur gear with their 47tooth(48p) pinion gear for a higher 2.60 fdr... Make sure you have other pinions from 40tooth(48p) up to 47tooth(48p) to cover all the possible gearing from 2.6 fdr to 3.06fdr... The tc4 easily matches their gearing, and then some!!!....
I Race VTA at 4 Tracks in the Summer.
Personally I'd either wouldn't race at the second track or would change classes. With a straight that long VTA racing you may aswell bring a book as long as it would take to make a lap.
...The Second track is Anything goes its a Huge outdoor asphalt 200+ ' strait that is where My Tc4 has the most trouble ( the FDR's they Run are from 3.0 - 2.8) Can't match their gearing with the Tc4's 2.5:1 trans. ( Yes I did dremel out the bracing under the pinion gear )
Don't let the "gotta go low" mentality get to you. If you can carry corner speed you only need to keep up on the straight to be competitive. If you need gearing help, come talk to me next time we are both there. Not too many people running TC3s anymore so you should be able to find me easily. My USGT car, also a TC3 always has a BMW shell.
So did we ever figure out if the gear diffs posted a few pages back will work in the tc4?
Im new to the tc4 and just getting started with it and was wondering if someone could tell me if the tc4 FT manual set up advice works on the club car as i only got a 2 page manualfor the club car and can only find a ft 1
http://www.teamassociated.com/pdf/ca...rtr_manual.pdf
They have setup sheets on this page as well...
http://www.teamassociated.com/setupsheets/TC4/
I think Associated has the manuals mismarked on their web site. This one is under the second "RTR" heading but is actually for the standard car I think. Probably more helpful than what you have.
I was hoping for the gear diffs for their tunibilty. I've been trying to get my car to rotate tight corners quicker and a gear diff would help there.
