Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 03-28-2013, 08:47 AM
  #11311
Boomer's Avatar
mcmaster.com - they have just about everything you can imagine.
Boomer is offline
Old 03-28-2013, 10:09 AM
  #11312
slowclod's Avatar
this is the tc4 i picked up yesterday. i was told its a club racer, is it? i'm new to tc4
slowclod is offline
Old 03-28-2013, 10:14 AM
  #11313
DarthRacer's Avatar
WoW some maintenance issues there. Did you get it cheap? It could be the RTR or club racer, same thing really.
DarthRacer is offline
Old 03-28-2013, 10:20 AM
  #11314
slowclod's Avatar
lack of maintenance!!! i am going to take completely apart, clean, lube, and replace all the messed up broken parts. i feel like i got a good deal. it came with some parts that i am going to sell so that should bring the over all cost down
slowclod is offline
Old 03-28-2013, 10:47 AM
  #11315
IndyRC_Racer's Avatar
The TC4 pictured above may have started out life as a Club Racer kit (http://www.teamassociated.com/cars_a...C4/Club_Racer/), but it has a few obvious upgrades such as...
- blue aluminum threaded shock bodies
- blue aluminum shock caps
- blue aluminum cvd bones
- blue aluminum screws
If that car doesn't have a solid front spool, then it is an upgraded RTR or previous version tub chassis TC4. Either way it looks like you got a good deal (if the price was right).
IndyRC_Racer is offline
Old 03-28-2013, 10:52 AM
  #11316
slowclod's Avatar
could it have started out as a factory team?
slowclod is offline
Old 03-28-2013, 11:31 AM
  #11317
beemerfan's Avatar
Trader Rating: 39 (100%+)
No. The Factory Team TC4 has a carbon fiber chassis and top plate. As old as those tires are, that looks like one of the previously released versions rather than the more recent Club Racer. I'm not sure about the TC4, but the TC3 came in different versions like the Racer, Team, Factory Team and RTR. Each one had a few differences and upgrades. I think Associated did the same thing with the TC4, but I'm not familiar with the differences.
beemerfan is offline
Old 03-28-2013, 04:15 PM
  #11318
Evilcon666's Avatar
I can't find a driver that will fit the 4-40 what size of a driver would I use? Would I get away with using a 4 or a 5? I was sold some team losi ones and can't find the right driver size to set the nut down in place. Suggestions, this is the last thing I need to get her running again lol. So really excited to get her going again. Also is it supposed to be a tight fit? I can't seem to get the nut to sit right for some reason.
Evilcon666 is offline
Old 03-28-2013, 05:51 PM
  #11319
NutDriver's Avatar
Trader Rating: 30 (100%+)
IIRC, it's a 3/32.
NutDriver is offline
Old 03-28-2013, 05:58 PM
  #11320
Evilcon666's Avatar
But this package of team losi brand should work right? I mean it should be just a standard mini 4-40 I need?
Old 03-29-2013, 06:04 AM
  #11321
Any nut that fits into the steering rack will work for you. Any 4-40 bolt will thread into any 4-40 nut.
anr211 is offline
Old 03-29-2013, 08:15 AM
  #11322
A normal 4-40 nut uses a 1/4" socket, the mini 4-40 nuts use a 3/16" socket, 3/16" is also the normal size for 2-56 nuts.
4-40 screws will usally use a 3/32" or 1/16" hex driver
Rojna is offline
Old 03-29-2013, 09:39 AM
  #11323
slowclod's Avatar
what kind of lube (shock, gear) do you guys use on your rides? gonna start to disassemble soon.
slowclod is offline
Old 03-29-2013, 11:18 AM
  #11324
heretic's Avatar
shock rod: green slime
Diffs: AE black for the thrust, AE white or translucid for the 3/32 balls.
Bevel gears: pretty much any grease will work, but I've never noticed any difference when running them dry so that's what I roll with. If you really want some grease in there, use a tiny amount of white AE diff grease just to be sure you don't mess your diff should some of that gear grease get inside the diff.
For that reason you also don't want to put too much black grease on the thrust. It won't work any better drowned in grease, and the surplus can actually work its way up around the screw and mess up the white grease and diff action. It's admittedly uncommon with AE diffs, but it's better to be on the safe side.
heretic is offline
Old 03-29-2013, 11:43 AM
  #11325
heretic's Avatar
Oh, and for the CVDs, Tamiya AW grease. Expensive but well worth it in the long run. Of course if you run on a dirty/dusty track they'll require regular cleaning and re-greasing, but that's no reason to run them dry, they wear faster, bind when spinning and rust appears quickly.
heretic is offline
